Car taking forever to "warm up" after oil dilution TSB
Swey
Swey
New Jersey
2016 chevrolet silverado custom dbl cab
Changed out my thermostat today, all issues are gone and car warms up properly, temp doesn't drop during idle.
Swey
Swey
New Jersey
Also, For reference, the updated recall fix for the oil dilution, they are no longer replacing the A/C control module and are only reprogramming the BCM (body control module).
If you already had the recall done, there is no point in going back for it as the software versions are the same.
MattyNice
Matt
Charlotte, NC
2018 Honda Civic Si
From my reading it seems the problem stems from the time it takes the engine to reach normal operating temperature. I observed from the start of winter it takes this car longer to warm up than any car I’ve had in the past. Thought it was weird for such a small motor. I do check my oil every so often and have not seen any rise in the level ever.
latole
Vaudreuil,Quebec ,Canada
Funny ! To me my Civic take shorter time to warm up than our all previous car in the family.
Temperature digit is not there and I feel warm air in vent after 5 minutes driving in city speed at 5 F
bembol
SHIFT_
Rafael
GTA
17 FK7 Sport Touring, 20 Audi Q3 Progressiv
Time to sell the Honda and get something nice. 2019 Audi RS5 seem like a good replacement ;)
My dream car (in the $100k lol) I would buy today.
2tango2
NH
2018 Civic Hatchback EX- Lunar Silver
My temp is all over the place. If anything it gets blistering hot even when it is set in the 60's? If I bounce down to lo and back up again it seems to right itself...
I live in NH and haven't been notified of the oil dilution TSB as of yet...wasn't there a memo about cold weather owners being notified?
civicdabest-foo
South central Canada
Civic x 1.5L turbo CVT
They're reprogramming the BCM? :spaz:Really?
I just had the service done this week, dealer wasn't very clear on what exactly was done.
But next week I'm scheduled to get the BCM replaced because of the door proximity sensor issue that causes auto unlock to not work.
I wonder if the dealer knows they'll have to reprogram the new BCM, if that is the problem.
This is great drama :D
civicdabest-foo
Is this a DIY'able job?
I had the service recall done and it warms up marginally faster. Granted this is Canadian polar vortex winter weather at -20 Celsius average.
YEGFK7
Edmonton
'18 Sport Touring Hatch
I've been having a similar issue, with my vehicle taking 30-40 mins of continuous driving to get fully warm, and that's WITH my using a block heater. If I so much as idle at a stoplight the thermostat drops immediately. That being said I had the work done right before two straight weeks of -25 C weather. It's supposed to warm up in the next couple of days so I'll see if there's any difference, if not I may get in touch with the dealer.
Swey
Swey
New Jersey
It's pretty easy if you have a decent set of tools, basic stuff really. It's easy to make a huge mess, but since i work at a car dealer, I just borrowed a lift after work, threw my car up in the air and drained my system then took the two bolts out of my thermostat and went at it. Took me a lot longer than I would have liked because i had to find a good way to work around tight spaces to get everything out, but yes to answer your question it's very easy and straight forward. I would definitely suggest referencing something online just to make sure you do everything correctly.
Swey
Swey
New Jersey
I'd definitely ask them about that if you're still having issues.
Also do keep in mind that while the thermostat may look good (after putting it in a boiling bowl of water) It seems to function properly, but I'm pretty sure it's opening prematurely which also causes the car to cool down too soon.
absolude
GTA
KW SC 2007 CSX Type S, 2023 PWP Si
Same for me, except for the Mazda3 but that engine has very high compression and is designed to warm up fast.
It seems to be a problem for the CVT cars mostly.
Never had it drop temperature on idle even in 20 degrees below freezing.
SI_honda_2k17
Can
Honda civic si
When i get back from work, i have a 40km drive where for maybe 30-60 sec i don’t even have to touch the gas since im going downhill. In that situation, when it’s really cold -15 degre celcius or less i see the engine temperature indicator going down quickly. It start going up again once i start to reaccelerate. I noticed it only since a couple of week but i don’t know if this situation was present before the recall too.
Not sure it is a real issue but i must say it is the first time i see that on a car.
absolude
GTA
Going downhill with no throttle input seems to be the ultimate test. Feeding cold air with little combustion.
Surely beats stopping at a stoplight for a minute of two.
Maybe i not that abnormal, being a small engine that needs to cool down a turbo...Could be hard to find a happy medium between the ability to cool in summer and not letting it cool down too much in the winter, for a relatively cheap car...
