baldheadracing
- Craig
- Jan 4, 2017
- 44
- 1,248
- 1,382
- Canada's capital
- FK8
Not sure if you are familiar with Brembo calipers, but they can be expensive to replace, and salt kills them as soon as any anti-corrosion measures are breached. (Aluminium + road salt+sand = instant corrosion).also winter tire options as well to fit the brakes....
On the plus side, Brembo calipers are very easy to maintain, so if you are handy, then every few weeks as soon as road salting starts (yes, that often) you can clean the salt off and pull the pads and check that the anti-corrosion seals surrounding the pistons are still good and well-lubricated, ditto any anti-squeal measures, pad retaining clips, etc. If you do that, then you can take action as soon as the anti-corrosion seal rubber is torn - and the rubber will eventually tear - and save yourself a few thousand dollars.
