Canadian Battery Replacement?
Tags:
  1. 250GTCalifornia
    250GTCalifornia Senior Member
    May 5, 2017
    217
    57
    Civic
    Anyone know what is a good replacement battery for our OEMs? I know we're using different batteries than our southern neighbors.
    I'm being suggested batteries with 400-450 CCA on websites, but our OEMs use 550 CCA, so I'm definitely not going to use less than OEM CCAs. What is everyone else using?
  2. daPyr0x
    daPyr0x Senior Member
    Jan 10, 2017
    91
    36
    K-W
    2016 EX-T
    I haven't replaced the battery in my Civic, but if/when I do chances are I'll be purchasing an Optima. In my previous vehicle, I did not treat the battery well (stereo, HIDs, lots of short drives, lights getting left on, etc.). Where the OEM would begin failing, the Optima always came back. Even after running the battery near dead by leaving lights on overnight, it would still start. The Optimas lasted me 3x as long as the OEM.
  3. OP
    250GTCalifornia
    May 5, 2017
    217
    57
    Civic
    Optima's website gives me Yellowtop D51R with a 450 CCA. Which Optima would you install?
  4. marauderguy
    marauderguy Senior Member
    May 20, 2017
    258
    182
    Alberta
    2017 Civic Touring
    The Everstart Maxx from Walmart is a decent battery with a good warranty. Group size 35 is 640 CCA. Most places online think that the Canadian Civics use a 51r but I know mine is a group 35.
    Motomaster ultra AGM is an excellent battery made by Exide. It is also 640 CCA. A little pit pricey but well worth it.
  5. M1KL83
    M1KL83 Senior Member
    Mar 31, 2018
    152
    34
    Ontario, Canada
    Michael
    2018 Civic Hatchback LX 6MT, 2002 Honda Accord SE 5MT
    Did you have any luck picking a battery?
    I'm having the same issue of Canadian websites listing d51r battery size for my 2018 Hatchback but all signs point to us having Group 35 size batteries, not d51r.
  6. OP
    250GTCalifornia
    May 5, 2017
    217
    57
    Civic
    You can get one from Costco. They have a Group 35 Kirkland battery.
    M1KL83 thanked this.
  7. SCOPESYS
    SCOPESYS Senior Member
    Aug 27, 2018
    2,510
    1,439
    MD
    Geoff
    I was interested in the difference, so I did some research...
    Sharing will group.
    COMPARISON D51R vs Group 35
    d51r battery DEEP CHARGE----- $240
    Model: D51R
    Weight: 26 lb
    C20 Capacity: 38 Ah
    Post Type: SAE Post
    CCA: 450 Amp (lower)
    Width: 5.06 in
    Length: 9.31 in
    Height: 8.94 in
    Key Benefits
    • Deep-cycle and cranking power
    • Up to 3X longer life
    • 15 times more vibration-resistant
    • Virtually spillproof
    • Mountable in virtually any position
    • Maintenance-free
    • Faster recharging
    • Optimal starting power
    • 300+ discharge/recharge cycles
    Walmart Group 35 Battery $ 75
    Cold Crank Amp 525 (Higher)
    C20 Capacity: 38 Ah <<< Guess from typical Group 35 Battery - sames as D51R)
    (L x W x H) 9.75 x 6.88 x 8.88 Inches
    Cost of owership about the same ?
    D51R is x3 the price, but claims x3 the life
    D51R is a DEEP CYCLE battery, so should do better if heavily discharged.
    If nothing else, the Optima D51R wins on "Cool Looks"
  8. peterletran
    peterletran Senior Member
    Apr 2, 2017
    158
    36
    Philadelphia
    2017 Civic EX-T Coupe 6MT
    I need the part numbers to convert my "American Civic" from D51R to Group35.
    I've searched everywhere. Not sure if I just take out the old battery box and
    shove the bigger battery in. Not sure if the D51r tie down will work on the 35.
  9. 123sillyboy123
    123sillyboy123 Senior Member
    Jun 3, 2018
    879
    231
    Markham, Canada
    2019 CTR, 2018 Honda HB sport
    can anyone confirm that toronto civic battery is group 35 not D51R?
    thanks
  10. M1KL83
    Mar 31, 2018
    152
    34
    Ontario, Canada
    Michael
    I'm also in an Ontario Civic (hatchback LX) and I was almost convinced that I have a group 35 until I looked under the hood and see written on top of my factory battery - 450 cranking amps. I can't find it documented anywhere in my owners manual exactly what battery I have.
    What does your battery say on top?
    I will snap a photo and post so we can compare.
    Thanks
  11. TimberWolf
    TimberWolf Senior Member
    Oct 12, 2016
    337
    327
    Occupation:
    forensic pathologist (ret.)
    Bowser, BC, Canada
    '17 Civic Hatchback Sport Touring 6MT
    Battery size is not the same as cca. In order to figure out the battery size, you should measure it.
  12. SCOPESYS
    Aug 27, 2018
    2,510
    1,439
    MD
    Geoff
    There are 3 major battery parameters that are important.
    CGA
    Capacity
    Deep Cycle
    CGA is the amount of current that the battery, when charged, can supply at a given temperature while maintaining a given voltage.
    Capacity is the amount of time the battery can last, on a given load (given current)
    Deep Charge is if the Battery will survive repeated full discharges, without major deterioration.
    It's possible to have a battery with a High CGA, but a low capacity.
    It can provide the current (when fully charged) to start the car, but not for very long.
    Example: Small Lithium emergency starting devices.
    Then again, you can have a physically BIG battery, with lots of Capacity (last a long time), but can only provide a limited current when put on load.
    With that being said, getting a PHYSICALLY bigger battery does not necessarily give you higher CGA - that depends more on the construction of the battery, but a Physically BIGGER e battery will typically give you more CAPACITY, so will allow you to listen to the radio with the engine NOT running for longer.
    The question is, why do the Canadians get a Physically BIGGER battery, with approximately the same CGA as the smaller American battery ?
    Either they need the Capacity because it takes longer to start the car in their colder climate .. or .. They need listen to the Radio a lot more with the engine not running. ?
  13. TimberWolf
    Oct 12, 2016
    337
    327
    Occupation:
    Bowser, BC, Canada
    Again, none of that has anything to do with the physical size of the battery. If you are looking for the actual size, measure it and compare it to the chart:
    https://www.jegs.com/Sizecharts/bcigroup.html
    You can have different battery capacities within the same group.
  14. peterletran
    Apr 2, 2017
    158
    36
    Philadelphia
    This isn't a fantastic photo, but I thought it might help some people.
    The battery on top is the Group 34 and the battery on bottom is the 51r.
    I believe, in most cases, the bigger battery will have a higher reserve capacity and better deep cycling abilities.
    Think of a cellphone and it's MAh rating. Higher means longer battery life.
    A cell phone with a 10000 MAh will last much longer than one with only 200 MAh.
    (I'm exaggerating. I've yet to encounter a phone with a 10000 MAh battery).
    Also, most bigger batteries will have a higher Cold Cranking Amp.
  15. marauderguy
    May 20, 2017
    258
    182
    Alberta
    2017 Civic Touring
    If you have 450 CCA, it is not a group 35. My factory battery in the Canadian Touring is 550 CCA.
    Measure the width.
    Group 51r Approx 5 inches wide
    Group 35 Approx 6.75 inches wide
