Can you replace fog light bulbs with 50w LEDs?
Deleted member 35719
I see that the original halogen fog light bulbs are 35w H8, the most common LED replacement bulbs on Amazon are 50w, are they going to work as fog light replacements? Or is it going to draw too much power and potentially cause damage or simply not work?
NonyaBisness
United States
2016 Civic EX-T
given how thin the wiring for the headlights on this car are I wouldn't replace 35 watt bulbs with 50 watt bulbs, the whole point of LED is to be a lower power draw not higher.
Isn't the 50W for the pair of LEDs whereas the 35W halogen is for a single bulb?
charleswrivers
Charles
Kingsland, GA
I'd assume the "50w LEDs" are lumen equivalent (or more) to a 50w halogen bulb. They likely consume a fraction of 50w. If you post a link, we could likely verify this for you.
As an example... a set of H11 Hikaris were supposed to have about 3x the lumen output of stock halogens. Hikari stated they consume 28w, and the halogen bulbs generally draw 55w. Dual Hi/Lo filament bulbs are typically 55/65w.
I'd be shocked if fogs draw any more than headlights, assuming those were specifically made for that application.
latole
Vaudreuil,Quebec ,Canada
35 watts halogen bulb draw 3 amps ( 35w / 12volts
50 watts LED draw same current as a 9 watts "normal" bulb ; 9 w / 12 v = 0.75 amp
In theory we can say that to draw 3 amps like the 35 watt halogen, we should install a 140 watt LED
It is safe for a car ( or anything ) to use LED where you have any kind of bulb
shoegazer
Raleigh NC
2018 Civic LX Coupe 2.0 (CVT)
Agreed that I believe it would be okay so far as power consumption. Remember that there is a fuse that protects the wiring. If you try to draw too much amperage through; the fuse is designed to be the sacrificial weak link.
But also agree that improper use of LED lighting on the road gives me a headache.
Good luck.
xaviersayys
Xavier
Xavier
San Francisco, CA
2017 Civic EX-T
Is it safe? Yes. Can you? Yes. Should you?
Absolutely not.
Your foglights will now be totally useless as foglights, and every time they're on all oncoming traffic will be able to see is your LED foglights in reflector housings. If you want LED foglights, get Morimoto XBs or Touring OEM lights.
I second this.
n2da2nd
It's Senor Bane to ya
Nam
DFW
Yeah 50W is a bit too much. Check out my Amazon store, I have the dual color fog lights that you can have both white and yellow output on the fog lights. They are 35W.
www.amazon.com/shop/civicsocialclub
THATSi
Nick
Orlando FL
17 Civic Si
As an electrician I can tell you that you are correct, it's 50W equivalent, will not draw 50W
charleswrivers
Charles
Kingsland, GA
...as an electrician, though not a real/licensed one, just one thatā€™s given the title and a little training by the navy and turned loose to do their worst and to figure it out as we go... I appreciate it. :thumbsup:
THATSi
Nick
Orlando FL
17 Civic Si
Ok idiot, goto home depot and buy a 50 or 60W led bulb and put a meter to it, if you can even figure that out and post your results of the draw, it's ok your meter won't do watts, I'll convert and do the math for you
Deezy
Daniel
Covington, Ga
2018 Civic LX Sedan 6MT (FC2)
I think you misunderstood his post. You might want to read it again.
charleswrivers
Charles
Kingsland, GA
Really? I was agreeing with you. I am well aware that theyā€™re marketed as an ā€˜equivalent toā€™ incandescent bulbs based on their lumens.
I was just stating Iā€™ve been an electrician in the navy for 17 years, though I donā€™t dismiss the licensing and abilities you have in your trade. Youā€™re being an ass.
THATSi
Nick
Orlando FL
17 Civic Si
Debatable on who's being an ass, but whatever, I wasn't trained by the navy, or any other branch of the military either, eligible for my license in 18 months tho, didn't mean to come off wrong but at first glance it was a bit insulting
charleswrivers
Charles
Kingsland, GA
An insult wasnā€™t intended... but thereā€™s also no offense where none is taken. But, as an electrician, you can decide whether or not you want to tell me Iā€™m correct again. (thatā€™s a joke... take it as one this time... for the love of god).
Power is easy as PIV my friend... and even throwing in a power factor if needed, or multiple phases if needed, itā€™s an easy concept. Ohms power law needs not be used to attack someone.
I was mostly knocking on myself for not being licensed, though given my experience onboard subs for years... thereā€™s pretty much nothing I canā€™t fix. When we go through our year and a half of training, which is nuclear more than electrical, were pretty trade-dumb and learn by having to fix everything that breaks... and everything does. That first year or so is exciting at times (which isnā€™t a good thing with electricity) and humbling.
18 months huh for a license though? Congratulations. Trades are a under appreciated skill in todayā€™s college-to-be-successful world.
Still... Iā€™ll be sitting here with my fluke, waiting for my lesson. Completing circuits with a multimeter to read current puts the F-U in fun when weā€™re playing with 110v. I wonā€™t need to go get a bulb at Home Depot though... every lighting receptacle in my home has an LED bulb in it, and has for over 5 years.
Honda Civic 10th gen Can you replace fog light bulbs with 50w LEDs? 314587CF-F490-48F4-865B-ABEECD9E2209
Donā€™t forget to get the leads right! I donā€™t have a clamp on so weā€™ll have to get dirty with it. ;)
