Can someone explain clutch slip better than...google?
  1. consensual_induction
    consensual_induction Senior Member
    May 27, 2019
    162
    77
    Occupation:
    Medical school student (reconstructive surgery)
    Clevelnd
    Turbo
    2018 Subaru Sti, 2019 civic Si, Scion Fr-S, Nissan 350z, Mitsubishi Evo X
    i read articles, reddit threads, im still just not getting it.
    how will i know its happening? i think ppl were saying you press gas but dont accelerate? how can you tell between that and say flashing a new tune that has a boost curve that falls off? wouldnt that feel the same? basically i got a ktuner and cant tell if im slipping or not. base map on 19.5/23, and I have tsp just scared to upload it.
    I did WOT in second gear, and towards the top of the rpm range it stopped "pulling" (as hard), is that slip or the boost curve falling off (i would assume that, since I've had cars with bigger turbos that...dont...but they came with 16lbs or heavier clutch pedals)
    ty fam <3
  2. ONEPNT5.Si
    ONEPNT5.Si Senior Member
    Jul 8, 2019
    83
    61
    Occupation:
    Air Traffic Controller
    Ventura, California
    Dustyn
    2018 FC1 Si
    It's kinda hard to explain. You just know it's happening. Your RPMs will shoot up way quicker than normal, but the car won't go anywhere unless you back off the throttle and ease back into it.
    Nethlo, luigi2120, garf117 and 2 others thanked this.
  3. arpypat
    arpypat Senior Member
    Jun 29, 2019
    286
    256
    Occupation:
    Electrical Engineer
    Kansas City
    Arpan
    2019 Civic Si Sedan ABM
    What you're explaining, the WOT in 2nd gear and it stopped "pulling" at the top of the RPM range , is actually the fuel cut-off at redline. You were already in gear and not changing gears, so that's not your clutch slipping.
    consensual_induction thanked this.
  4. repeet
    repeet Senior Member
    Jun 3, 2017
    609
    560
    Occupation:
    Retired
    Fort Mill, S.C.
    '17 Civic Si Sedan
    It's really hard to describe. If you've done it, then it is unmistakable, sometimes. Basically you just "feel" that the engine isn't pulling like it usually does. Yes, power fall off kinda feels like it, but not really.
    When it's really bad, it feels like your driving an automatic transmission. You press the gas, the engine revs up, and then the speed of the car catches up. But the type of clutch slipping these guys are talking about occurs in the upper RPMs, and would kind of feel like a power drop off.
    So the real danger here is that unless your sensitive to it based on past experience, that you wouldn't notice it until is does get obviously bad.
    So yes, you're entering the cadre of daring people who are pushing your car to its limits, with all of the "danger" associated with it.
    Most people who tune on this forum end up needing a clutch sooner rather than later.
    Some say that if you limit boost to less than 250 ft./lbs. then you can get away with it. Some say that would be equivalent to a 21 pound, or better yet 19.5 pound, tune. Since the Si factory limit is 20 pounds, you would think that you could get away with 21.
    I don't have a tune. I'm just entertained by all of the people on here who are.
  5. OP
    May 27, 2019
    162
    77
    Occupation:
    Clevelnd
    Turbo
    that was actually really well and concisely explained lol, despite your disclaimer
    ONEPNT5.Si thanked this.
  6. OP
    May 27, 2019
    162
    77
    Occupation:
    Clevelnd
    Turbo
    I think i completely get it, including the part about not being able to get it since I have no prior experience if its in the upper band. I uploaded TSP, ill stick with 21psi, as thats plenty good enough for my DD civic lol.
    Honestly the clutch needs to be replaced from the factory anyways. when I test drove this car, I drove my sti to the dealer, and the for like the whole test drive, everytime I pressed the clutch I accidentally slammed it into the floor, enough times and noticeably enough that the salesperson said something cuz he heard it thunking against the footwell wall lol.
    repeet thanked this.
  7. ONEPNT5.Si
    Jul 8, 2019
    83
    61
    Occupation:
    Ventura, California
    Dustyn
    2018 FC1 Si
    A buddy of mine refers to a car with a slipping clutch as having "infinite gears". Not infinite in the sense that you actually have an infinite number of gears, but infinite as in, the gears that you do have never end. The car just revs up and continues to try to work to get somewhere, but doesn't move.
    aighead thanked this.
  8. OP
    May 27, 2019
    162
    77
    Occupation:
    Clevelnd
    Turbo
    so a free DIY mod to turn it into a mazda rx7!!!! (joking)
  9. OP
    May 27, 2019
    162
    77
    Occupation:
    Clevelnd
    Turbo
    also, that sounds horrible
  10. ONEPNT5.Si
    Jul 8, 2019
    83
    61
    Occupation:
    Ventura, California
    Dustyn
    2018 FC1 Si
    Pretty much lol.
    it is. After about 3 months of TSP Stage 2, my clutch started to slip pretty bad in 4th-6th, so I had a CTR retrofit installed.
  11. Nostake
    Nostake Senior Member
    Jul 27, 2019
    73
    kalispell MT
    jeremy
    2018 Aegean Blue Civic Sport Hatchback
    see more tuned SI needing a cluth sooner than non SI tuned Civics, i think all civics except the R got the same raggedy clutch :( SI the weakness is just more apparant because the car makes a bit more power and torque especially when tuned.
    repeet and Honda_RacerX thanked this.
  12. tehSteve
    tehSteve GrayBeard McGootch
    Sep 3, 2017
    587
    366
    NJ
    Si
    My stock clutch started slipping on the TSP Stage1 tune. Traditionally, the RPMs should should shoot up fast, yet you do not feel it pulling any harder.
    Theoretically, you should immediately feel the slip if you gun it earlier in the RPM range because that is where the vehicle makes the most torque 2500-3200rpm.
    Now here is what happened to me. - I gunned my car @ 2500rpm in 3rd gear. Revs climbed to 4k and just HOVERED @ 4k RPM for a few seconds. The revs didn't climb up any higher. I immediately noticed the car just stopped pulling and looked at the rev counter for about two seconds. After I saw it just hovering there, I realized "from somethings wrong" to "oh that must be slippage".
  13. ne0guri
    ne0guri Senior Member
    May 22, 2017
    777
    755
    Mars
    2017 White Orchid Pearl Civic Si Sedan
    There is also a sound that is unmistakably clutch slip. It sounds kind of like someone dragging a heavy carpet across the floor (I assume this is the sound of the clutch or whatever rubbing instead of grabbing against the disc). When it happens you will know immediately. If you’re still unsure then you haven’t slipped the clutch yet.
  14. Dan9908
    Dan9908 Senior Member
    Jan 8, 2019
    175
    109
    PA
    19 Accord Sport 2.0/A10, 05 Civic LX
    Didn’t read the thread, but- if you are familiar with how a clutch functions, it’s pretty basic.
    Even if you’re not that knowledgeable or experienced- sound, feel and your tach are pretty good indicators
  15. A2typeR
    A2typeR Senior Member
    Oct 14, 2016
    512
    470
    Ann Arbor
    2019 Honda Civic Si sedan (TSP stage 1) 2016 Mazda Miata Club (Brembo BBS pack)
    It’s kind of like the thingamagigy goes down while the other one goes up with some gas and Revving and the car kind of like goes be bop buu dooowweeyyyupp pop ping bang chitty chitt poo pow. And then it moves
    Always remembers to eat your J E L L O!
    ne0guri thanked this.
