Came out to my car today and saw this....
  1. Captaindicki
    Captaindicki Senior Member
    Mar 16, 2018
    1,007
    911
    Occupation:
    Whatchoo Talkin ‘Bout Willis
    Ontario
    2018 Honda Civic Si Coupe (sold)
    Maintenance Minder
  2. Charley-TX
    Charley-TX Senior Member
    Aug 25, 2017
    341
    191
    Austin TX
    Charley
    2017 Civic EX-T
    This...^
    I've worked 10+years at the dealer service dept.
    Dealers call it a different name such as quick-lube, express service or what not. These are service that can be done quickly by a person with minimal onsite training. These are the high school kids. I can teach a monkey how to rotate tires, drain and fill oil +filter change. These are minimum wage jobs. They learn on the job under supervision and usually there is someone to help them out if needed.
    These services are performed by different tech than your check engine light problem.
    These lube techs do not need to go to a technical collage to perform such service.
    However, they can do their jobs well, if they are not stoned or distracted by twitter snapchat or whatnot... or sometimes get called off to top of this old lady's windshield wiper fluid and when they come back they forgot to tighten the drain plug.
    They can make a mistake like anyone else.
    Some dealers install new drainplug everytime and torque to spec every time. Example: my VW dealer did this, even when first 3 oil change was free.
    If a quart of your oil leaked out, nothing bad will happen to your engine if the car was driven only for a short time.
  3. OP
    jred721
    jred721 Senior Member
    Mar 21, 2018
    1,346
    927
    Northern Virginia
    James
    '18 Honda Civic EX, '18 BMW M550i, '13 Mercedes ML350
    Maintenance Minder
    Israel thanked this.
  4. Jimmyson27
    Jimmyson27 Senior Member
    Jan 5, 2019
    120
    Milpitas
    Jimmy
    Honda Civic Sedan 2019 Sprot
    im currently at 2,150 miles. When do you sugguest getting an oil change? Also do i need any other fluids changed?
  5. OP
    jred721
    Mar 21, 2018
    1,346
    927
    Northern Virginia
    James
    Just follow the maintenance minder. When your oil hits 15% oil life, that's when you should bring in your car for a change. Plus when your service is due, your car will tell you anyway. For the first service, all you need is an oil change a tire rotation if you want, nothing else.
  6. civicls
    civicls Senior Member
    Aug 8, 2018
    938
    432
    Upstate NY
    2017 Honda Civic EX-T, 18' Odyssey Elite, 07' Sienna
    You have to trust me when I say this, but Google reviews are so easily faked 90% of dealers and mechanic shops have a majority of fake reviews. Don't ask me how I know...;)
    jred721 thanked this.
  7. scoobysnack
    scoobysnack Senior Member
    Dec 23, 2017
    295
    226
    Walnut Creek, CA
    no
    2018 CTR, 2008 Volvo C30, 2009 Infiniti G37
    You should be able to quickly determine if your engine fluid levels are normal. With that amount of liquid on the ground you would see a drop in something (radiator, engine oil, brake fluid etc or some combination of those). If all fluid levels are 100% normal then you'd move to a less likely source of fluid, like a CV boot. Should be easy to find the source.
    Rickmeister 48 thanked this.
