kidcon
- Nov 8, 2016
- 5
- 280
- 140
- Brooklyn
- 2017 EX hatch
- Vehicle Showcase
- #31
This has actually helped, a lot, if possible i'd like to learn more from you - maybe not in a forum setting but somehow a way for you to be more in depth with things.Your freer flowing exhaust piping allows exhaust gases to exit the turbo faster. The faster the turbine spins, the more boost pressure is created on the compressor side. With a smaller exhaust, pressure builds up behind the turbo slowing down the exhaust gasses and how fast the turbine spins.
The turbine (the exhaust side of the turbo) is like a pinwheel. If you try blowing through a straw at a pinwheel, you can get it spinning, but it takes effort. If you blow on it through a piece of garden hose, you can get it spinning more quickly because more air can flow over it faster. A wastegate is like having a hole in the straw/hose that you can open and close to limit the air going to the pinwheel, let's say by covering the hole with your finger for example.
It's not exactly the same (backwards, but similar), but I hope that covers the basic idea in a visual way.
So why does this cause your wastegate to flutter? Freer flowing exhaust lets the turbo "spool up" faster, so the wastegate needs to work more to keep the turbo spinning at the right speed to make the boost you want.
Changing your tune probably won't affect your wastegate the way you think it will. The less boost you want to run, the more the wastegate works to bypass the turbo. So throwing a stock map on it will probably cause more "flutter" noise.
PS. I know I'm leaving out the thermodynamics, exhaust expansion, and pressure optimization stuff, but, I didn't want to add confusion.
