I don't know what "turbo stutters" means. Can you offer a better description? You're hitting the targets.So recently I have been noticing when I am accelerating my turbo stutters - I am not quite sure why.
Post #15 - he claims to have the stock BOV (which is BPV, but I digress)I don't know what "turbo stutters" means. Can you offer a better description? You're hitting the targets.
Get rid of the BOV and try again.
Yes I know it’s BPV I just put BOV because it was asked and forgot lol - but as far as the turbo sounds it’s like a really fast ftftftft instead of a steady sssssssssss sound if that makes any more sensePost #15 - he claims to have the stock BOV (which is BPV, but I digress)
Is this something you've just finally noticed or has it actually changed? Sounds like you're hearing bleed-off while the ECU is trying to maintain target boost pressure.Yes I know it’s BPV I just put BOV because it was asked and forgot lol - but as far as the turbo sounds it’s like a really fast ftftftft instead of a steady sssssssssss sound if that makes any more sense
It is something Ive noticed more and more while driving, i first heard it about a month ago but only for a second, now it is the whole time in boost. not sure what you mean by bleed off?Is this something you've just finally noticed or has it actually changed? Sounds like you're hearing bleed-off while the ECU is trying to maintain target boost pressure.
No, the wastegate controls how much boost the turbo makes by controlling how much exhaust is going to the turbine wheel. When the turbo is at the target boost the wastegate will open and close, potentially very fast and repeatedly, to divert exhaust away from the turbo and keep the boost pressure steady.wouldnt wastegate flutter be when i take my foot off the gas?
lol - not really. By Pass Valve or Blow Off Valve would be when you take your foot off the gas. Wastegate Flutter would be when the turbo is avoiding making more boost than desired. The wastegate is a flapper on the exhaust side of the turbo (typically internal, but can also be externally "gated") and while on most (older) turbo designs the wastegate is mechanically controlled with vacuum pressure and a spring loaded armature... on our cars it is electronically controlled.wouldnt wastegate flutter be when i take my foot off the gas?
Totally a guess, maybe reduced backpressure from the larger exhuast and less restrictive catless downpipe is changing how the car behaves on the tune you are running. If that's the case, would be good to ensure safe values are being seen in the datalog..... and arguably you could make more power if you were to get a custom tune performed (I would recommend Derek at IMW).
I could be completely off the mark though, it might not be your exhaust at all. The best way to verify would be to swap back the stock exhaust components, first the downpipe or the exhaust, each on their own, and together. Meaning stock dp, stock exhasut//catless dp, stock exhaust//catless dp, larger exhaust(you've already got that on the car). I know this would be a major pain in the ass.... so instead I would recommend you flash the "like stock" calibration and drive around for a couple days to see how it behaves.
Your freer flowing exhaust piping allows exhaust gases to exit the turbo faster. The faster the turbine spins, the more boost pressure is created on the compressor side. With a smaller exhaust, pressure builds up behind the turbo slowing down the exhaust gasses and how fast the turbine spins.Ah okay, thank you both for explaining more, I get the BOV/BPV stuff just not the wastegate. So my question is now then why would my exhaust be an issue, it is larger diameter than stock and more free flowing, same with my catless DP.
I also have this issue with ECON on because I am using the Dual map. Wouldnt the lower amount of boost pressure there mean the wastegate wouldnt be opening and closing as rapidly due to the wastegate spring being used at its intended pressures? or am i still not fully understanding?
Thanks for all the help guys @KTuner @Micah @typemismatch
