Buzzing sound when depressing clutch pedal at 5-6k rpm
Tags:
  1. zeppelin2
    zeppelin2 Member
    May 7, 2019
    Ottawa, ON, Canada
    2019 Honda Civic Type R
    I still got a second gear grind after adjusting the CMC rod to the point of resistance. Next up, I'm going to try adjusting the pedal stop to lengthen the pedal travel and then readjust the rod once more. But I already wish the pedal travel was shorter than it is and I don't like the idea of a high bite point for when bringing up the clutch.
    I'll keep an eye out on the 5K buzz over the next few weeks and report back if the CMC rod adjustment managed to fix it.
    WindJunkie thanked this.
  2. WindJunkie
    WindJunkie Senior Member
    Jan 14, 2016
    326
    195
    Jacksonville Florida
    2019 CTR #24,174
    Interestingly enough, I think my clutch catches very close to the floor. It only feels like two inches or so before the RPMs begin to drop and requires throttle as the clutch engages. I haven't adjusted anything from the factory and am at 7300 miles. Thanks for the info and yes please report back any corrections you're able to find.
  3. tbobtx
    tbobtx Member
    Oct 13, 2019
    TX
    tbob
    2019 Civic Type R 2011 Subaru Legacy 3.6R 2015 Volvo XC60 3.0L polestar 2003 Ford F150 Lariat crewcab
    I have this same issue when depressing the clutch while accelerating past 4500rpm. Dealer initially just changed out tranny fluid but that did nothing. Quick note, it also does this when rev matching. So if in 4th or 5th at 2500 or 3000 and down shift. The rev matching takes you over 4500-5000 rpm and get the same “guzzinggg” as I call it. Taking it into the dealership tomorrow and will see if cmc adjustment doesn’t the trick.
    I saw another post where they replaced the clutch bearing and plate to solve this but didn’t see any paperwork showing this did the trick.
    Will keep you updated.
  4. tbobtx
    tbobtx Member
    Oct 13, 2019
    TX
    tbob
    can you provide the paperwork for this fix so I can show the dealership?
  5. WindJunkie
    Jan 14, 2016
    326
    195
    2019 CTR #24,174
    Thanks, let me know how it goes.
    My father has a lot more experience with cars and the mechanics of the clutch, so I'm waiting until I see him next month to adjust anything. I plan on making the adjustment outlined in this video (which was posted to the second gear crunch thread):
  6. remc86007
    remc86007 Senior Member
    Mar 18, 2018
    435
    284
    Jacksonville, FL
    Ryan
    2018 Civic Type R
    Today has been a good day; the Jags won, and I think I've solved the clutch buzzing problem. I've only taken it for one test drive, but I think I may have fixed it.
    I have ktuner, so I removed the rev limiter when the car is stopped to make it easier to identify the source of the noise. I saw that there is a cotter pin that goes into a dowel that attaches the pedal to the rod that goes into the CMC. I noticed that the noise seemed to go away when I pushed the dowel to one side (there is a significant amount of play before it hits the cotter pin), so I put some adhesive on it to hold it in place. My first test drive has not had any buzzing. I'll report back in a couple days after I test it more and try to take some pictures of what I did if it continues to work.
    If this is in fact the fix, I'll be both extremely happy and annoyed that I waited over a year to look at it considering how easy this was.
    EnjoyDriving and handsoffsam thanked this.
  7. WindJunkie
    Jan 14, 2016
    326
    195
    2019 CTR #24,174
    interesting...I can check this out tomorrow in the daylight to see if this is loose on my end as well. I could wrap some tape around the pin to sort of secure in place as well. Worth a shot, a 2 second fix. I'll report back as well. Thanks
  8. EnjoyDriving
    EnjoyDriving Senior Member
    Sep 3, 2018
    541
    133
    Minnesota
    2018 CW FK8
    If you can include pics to show the parts and fix you did, it'd be very helpful too. Thx, and good luck!
  9. remc86007
    Mar 18, 2018
    435
    284
    Jacksonville, FL
    Ryan
    2018 Civic Type R
    I'll provide pics once I know I've fixed it. I drove it more today, and the noise is still there, but seems to be somewhat muted. I'm guessing my crappy adhesive job didn't hold enough. As soon as I get a chance during daylight hours, I'm going to look at it again. I don't feel like pissing off my neighbors early in the morning or late at night holding my car at 5k RPM haha
    I'll keep you guys updated.
    haojohn and EnjoyDriving thanked this.
  10. tbobtx
    tbobtx Member
    Oct 13, 2019
    TX
    tbob
    So The dealership still has my vehicle since last Wednesday. Though I provided them with the two fixes Windjunkie and Balazst78 had luck with, they said still need to run it through Honda techline to troubleshoot. I was a bit concerned when the master tech working on the car said he was not aware That rotating the piston rod going into the CMC would make any change to the operation of the clutch.
    so all I can do is wait for them to work through this rigid system of troubleshooting so they can get paid.
  11. SpooRk
    SpooRk Senior Member
    Oct 28, 2017
    285
    147
    FL
    18 RR CTR
    Has anyone taken their car in for this noise and successfully had it fixed yet?? This is frustrating because it seems like several people have the same issue but no one can say what's causing it.
  12. tbobtx
    tbobtx Member
    Oct 13, 2019
    TX
    tbob
    Apparently 2 people have if go back a few pages.
  13. SpooRk
    Oct 28, 2017
    285
    147
    FL
    18 RR CTR
    I took my car out today and did a little testing. I’m not exactly sure at what RPM the sound starts happening, but I can easily recreate it. When you’re stationary, you can only rev the car up to 3,500 RPM. I was able to find an empty road where I accelerated up to about 25 mph and put the car in neutral. At that point, I was able to rev up all the way to redline. I could duplicate the sound almost every time by pressing the clutch. If I didn’t press the clutch, the sound would not happen. This is why I don’t believe the sound we are hearing is from the wastegate.
    Speaking of the wastegate, I also finally heard the wastegate chatter that everyone talks about. This particular dealership told me they are aware of the wastegate sound and they are not replacing any of them under warranty because it’s “normal”. I’m not too concerned with that right now, so it’s not a biggie to me. What I am concerned with is the other sound I hear when I press the clutch.
    The Honda master tech told me there is a Honda field rep coming by on Monday so he will talk to him about it then. I’m hoping the field rep has heard of this and can advise my dealership on how to deal with it. I’ll let you guys know what I hear on Monday.
  14. EnjoyDriving
    Sep 3, 2018
    541
    133
    Minnesota
    2018 CW FK8
    any update on your end?
  15. remc86007
    Mar 18, 2018
    435
    284
    Jacksonville, FL
    Ryan
    2018 Civic Type R
    Not yet. I should have time to look at it tomorrow. The noise is definitely still there, but I haven't checked yet to see if it is because my crappy adhesive job failed or not.
