Buzzing sound when depressing clutch pedal at 5-6k rpm
Tags:
  1. TheBigG
    TheBigG Senior Member
    Oct 24, 2017
    235
    109
    Sweden
    Gabriel
    Civic Type R 2017, Kia Optima Sportswagon GT 2017
    I have this buzzing sound when depressing the clutch pedal at high rpm. No gear shifting, only putting the clutch pedal to the floor.
    In the last part of the video i'm holding the clutch pedal down and i'm reving the engine.
    As you can see, when in gear I don't have this sound.
    Any thoughts?
  2. RallyeX
    RallyeX Senior Member
    Apr 15, 2018
    47
    Occupation:
    PartsGuy
    London, Ontario
    2018 Civic Sport Hatch
    I typically hear this when shifting between 3500 and 4k rpms as well as randomly in the higher end of the rev counter. ive chalked it up to a small rattling of either the undercar shielding or interior plastics. It is definitely nothing harmful or to do with the drivetrain itself. this makes sense to me as ive had to tweak alot of plastics to keep the rattling to a minimum. Such as the passenger sunvisor, the cluster trim panel, the center hvac vent surround and other small things i am forgetting.
    TheBigG thanked this.
  3. haojohn
    haojohn Senior Member
    Feb 21, 2017
    72
    40
    Houston, Tx
    2018 Civic Type R PMM
    I have just finished my break-in period and pushed the car hard a few times. This also happened to me over 5k rpm. Had to dig out this old thread and found anyone with similar situation. Have you revolved the issue OP?
  4. OP
    TheBigG
    Oct 24, 2017
    235
    109
    Sweden
    Gabriel
    Nope! I'm waiting for the first service (in arround 30-35 days)
    I foud that this sound comes when you rev the engine past 4500-5000 rpm. When parked, the car won't allow you to rev above 4000 rpm but if you drive (15 mph it should be enouhg) and put it in neutral you will be able to rev it to 7000 rpm and then you will hear it clear.
    haojohn thanked this.
  5. haojohn
    Feb 21, 2017
    72
    40
    Houston, Tx
    I tried as you said yesterday and the vibration came up every time over 4500 RPM. Definitely an issue to be looked at. I will bring the car in dealer in a couple of weeks.
  6. haojohn
    Feb 21, 2017
    72
    40
    Houston, Tx
    OP I took my car in for diagnose, the technician took the all day but still not sure what the root cause is. At the end he put some insulation around where he thinks might be the vibrating source. It does reduce to a lower level but it's definitely still there. I might bring the car in again for second diagnose.
  7. Fk8 4343
    Fk8 4343 Senior Member
    Jul 31, 2017
    268
    249
    VA
    Greg
    17' Civic Type R, 17' CR-V Touring
    Where did the tech think the sound was coming from?
  8. haojohn
    Feb 21, 2017
    72
    40
    Houston, Tx
    Wasn't stated in the document that I got. The service adviser only knew that's clutch related.
    turboshawn and TheBigG thanked this.
  9. OP
    TheBigG
    Oct 24, 2017
    235
    109
    Sweden
    Gabriel
    I've booked the service for 20th of sept. I'll see what they will find...
    I don't think it is clutch related.
    The problem is that you can reproduce it only when car is roling because that stupid rev limiter when the car is parked.
  10. sean465
    sean465 Senior Member
    Apr 26, 2017
    79
    London
    Championship White Civic Type R FK8 R-03927
    It could be the turbo actuator rod. That's been the issue with a few lads over here. It vibrates on certain revs as its looser than it should be.
    Been replaced under warranty
    Tell your techies to check it!
  11. haojohn
    Feb 21, 2017
    72
    40
    Houston, Tx
    Sean, thanks for your info. Did you replace the entire turbo assembly or just the rod? What was it loosen from?
    I am bringing my car in again this week to the tech so hoping to give him a more detailed direction.
  12. Chris60
    Chris60 New Member
    Oct 26, 2018
    France
    FK8 - EK3
    Hi guys,
    I do have the same symptoms on my car: a buzzing sound and vibration in the clutch pedal while the engine is revving around 5K rpm with the clutch pedal pressed, excatly as shown in the video of this thread. A technical issue was opened by my dealer a couple of months ago but they don't seem to be very reactive...
    Have you had any feedback or repairs on your side ? Is it caused by the turbo actuator rod for everyone ?
    Thanks
    BTW, do I have to present myself somewhere on this forum ?
  13. haojohn
    Feb 21, 2017
    72
    40
    Houston, Tx
    I went to the dealer twice for this issue. The first time they put some padding around “the area” and it slightly reduced the noise/vibration. I couldn’t know where “the area” is because my advisor didn’t know either and didnt bother to find out for me.
    The second time they claimed they test drove another Brand new Type R from the lot by 2 top mechanics. They both agreed it’s normal and told me the brand new Type R is even louder on that issue than mine.
    And that’s that. Didn’t really bother to dig it further. Still bothers me sometimes.
    Chris60 thanked this.
  14. OP
    TheBigG
    Oct 24, 2017
    235
    109
    Sweden
    Gabriel
    Thay had the car for one and a half day and still no ideea where the sound is coming from. The dealer want the car for a longer period. Right now I need the car every day so I will wait until the motorcycle season will open again and than I'll let the try again...
    The car is working fine.
    UFO CTR and haojohn thanked this.
  15. haojohn
    Feb 21, 2017
    72
    40
    Houston, Tx
    Hey man thanks for the update. I am just too lazy to find another dealer to look at. All the sounds come from around 5000rpm so I just avoid that range for now.
