KhashTR19
Manual Mania
- Khashayar
- Dec 3, 2018
- 25
- 10
- Bloomington
- 2019 Civic Si Coupe, White
- Vehicle Showcase
Hello everyone! Im new to these forums and have purchased my first car ever!
My whole life I had a shitty car with broken windows and a driver side door I couldnt open so I finally got enough money to get this car and I feel like its the best choice iv made!
I have a son and this seems like a good family car too and later I can give it to him!
So yes..I bought the car and didnt know how to drive manual.
The guys at the dealership showed me how to drive manual for 3 hours and I practiced for 2 more hours and drove it home yesterday.
I can say im doing a decent job of shifting but I know I can do it alot smoother.
Hi GoldKing,
Wanted to let you know most of us here (I believe) are pretty experienced manual drivers. Speaking for myself, I've driven manuals of many makes for 40 years. So, my answers are based on personal experience (also personal driving habits) which can color the replies. Here goes...
Areas of Problem & Questions
1. Every time I come to a red light I switch to neutral (even if im 2rd, 3rd, 4th gear) and come to a full stop. Then when the light is green I switch to 1st gear and have a really hard time switching correctly..the car always jerks heavily and im not sure why...If I recall when it happened this morning I let go of the clutch alot more then I pressed the gas and thats when it jerked so I pressed the clutch back in more and was able to make it speed it. (I really need help in this area)
Just seems like you need more practice. First gear is the heaviest (in manual transmission parlance) along with reverse, which means it requires a bit more toggling between clutch and gas pedals. The best way to make sure you are shifting smoothly is keeping the RPMs more or less static initially. Then, once in second, you can accelerate.
Also, I wouldn't automatically come to neutral. Listen to the engine (watching RPM is another method, but it's safer to just use your ears and the seat of the pants feel of the car) to downshift slowly before coming to a stop. Naturally, shift to neutral before the car dies and as you wait at the light. If you are in a higher gear, brake, bring the RPM down some, then downshift 1-2 gears to, say, third or second. Now, your speed should be below 10 or so. Shift to neutral as you come to a complete stop. It's the safest way and also lets you save some gas. When the car is idling (in neutral), you are actually wasting gas. If in gear, the fuel cuts off when you take your foot off the gas and coast. There is some argument about using engine braking to help the brakes, as well, especially in slick conditions. But be careful because even engine braking can cause a loss of control, especially with the wide tires. Also, with antilock brakes, you may want to rely on the computer more. So, use both engine braking and the brake pedal judiciously.
2. If im driving for example on 4th gear going 40 mph and I see a light coming up...should I just clutch/break while on the same gear and when I'm fully stopped switch to neutral?
See above regarding shifting to neutral. I recommend downshifting (without revving the engine unnecessarily) and coast in gear until around 10mph before shifting to neutral.
3. When this car is parked and need to reverse... it seems that I dont need the gas and I can just use the clutch to back up (also use to slow or fasten the backup?) Is this the correct way of doing it?
You could do this in first, as well. But it depends on how fast you want to back up. You just have to be very gentle with releasing the clutch. Also, if you are parked on an incline, you will have to use the gas because you could kill the engine if you don't obviously.
4. How soon should I switch to 2nd from 1st?
Normal driving, I'd say around 2500-3000 RPM (a bit lower if you are concerned about fuel economy), and you are on a flat stretch of road. Inclines will make a difference again. If you are going downhill, you could switch more quickly because the car speeds up anyway (or maybe even start in second).
If you are driving for fun and with a bit of verve, the above is completely inapplicable. You basically shift at higher revs after the engine break-in period (say, on a race track). So, the answer varies based on driving situations/circumstances.
The above are all the pain areas im having with this car! If you guys can help me I would really appreciate it and thank you!
I will add that I am very proud of you for making the move to manual. KEEP THE MANUALS ALIVE. Enjoy and be safe.
Also if anyone lives in Orange County let me know we can meet up!
