davemarco
- Jun 3, 2017
- 148
- 2,638
- 1,458
- SoCal
- 2019 Civic Type R (CBP), 2013 Audi TTRS
Just downshift directly into the appropriate gear. Nothing wrong with skipping gears, as long as your speed is appropriate for that gear. Your example with moving the shifter into each gear on the way down without letting off the clutch is only effective because of autorev matching. If I were to find myself in sixth at 30 mph, I'd just clutch in, shift directly to 3rd, blip the throttle a little bit (because my revs wouldn't need to go up too much at that speed), and let out the clutch.Noob here as well. Let's say I'm coming up to a red light but still a good distance away. I'm cruising along in 6th gear at 45 mph and I think the light will probably turn green by the time I get there and I will probably slow down enough to be in 3rd gear. How do I downshift properly?
This is what I have been doing: Clutch to the floor, smoothly row through the gears from 6>5>4>3 (all while holding clutch to floor) as I slowly coast, let it auto rev match at 3, let off the clutch smoothly and then gas pedal as the light turns green.
Am I supposed to clutch down, shift from 6 to 5, clutch up so it auto rev matches, and then clutch down again for 5 to 4, clutch up, and then down again for 4 to 3? Or would that be something worse for the clutch and unnecessary?
Of course, there are times where I think I have to stop so I just coast in neutral but light turns green and I'll shift it directly into 3rd for example, is that also proper?
