Brakes
saiko21
Sai
Sacramento
2019 Civic Si Sedan (Sold) , 2005 Toyota Corolla (Sold)
If rust, why no vibrations at low speed?
U can't feel at low speeds. If rotors are warped you will feel it at above 50mph
Design
Southern California
09 MS3, 17 ABM Si Sedan
Vibrations only under light braking = irregular pad transfer.
Vibrations under heavy braking = warped or corroded rotor, or worn pads.
If the former, do a couple heavy brake cycles to clear the issue.
mis3
PT
Ontario
Mercedes, 2018 SI Coupe
I had the same problem. My next service showing was the infamous Canadian "Brake Service" (Service 9). After doing this no more vibrations and noises.
How much is this Service 9? Do you know what exactly did they do?
Oddwayne
Nj
19’ Si coupe & 99 ej6
This is what my rear brakes look like after 3 winters and 59 000 Km. The grooves started to get noticeable at around 50K, a pulsing feel under light braking started at around 55K. No noise and no vibration during normal driving though.
This is mostly highway driving.
Before this 2016 Civic, I had a 2013 and the same thing happened, but not as bad as this. The rear brakes and rear rotors on the 2013 were swapped at 72 000 Km.
Have you ever had your brakes service and taken apart in between all those kilometers?
TheComebackKid
Nick
Montréal, Québec
2017 MSM Civic Si Sedan
It was $200. They clean(including removing build-up rust), lubricate and inspect all the brake components.
It's expensive I know and I did it because my car is a lease and don't want any trouble for missed maintenance but I'm pretty sure a regular shop can do this for half the price.
I feel like since I'm in Montreal and we have winter with snow, slush and calcium for 5 months out of the year, a brake cleaning makes a difference.
My pads and rotors were fine btw.
mis3
PT
Ontario
I used to live in Montreal and now in Toronto. I never had to ‘clean’ the brakes in all the cars I owned before. Of course, they would brush off the rust in the brake areas every time they replaced the rotors and pads.
By the way, does Honda dealership still turn the rotors? They used to do this back in 2000 when I own the last generation of Honda Prelude. My dealership at the time (Lallier Honda Montreal) used to send out the rotors to a machine shop.
Old George
Georges
Saint Jérome, Québec , CANADA
2017 Civic SI
I turned rotors at the front ( in 2003 or 2004 )
The car was on a lift, with the wheels removed, they placed
a sort of tool that machined the rotors, without removing them.
The engine of the car was at iddle, at 2nd gear to drive the rotors.
I' ve never seen anything like it before.
It was a good job, at Honda Ste Rose in Laval, Qc.
TheComebackKid
Nick
Montréal, Québec
I never did a brake service on my previous cars either. My first 2 cars were used and out of warranty so I only did oil changes for maintenance. My mechanic never mentioned a brake service either. And like you said everything was cleaned when I changed the rotors/pads.
The car I had before the Si was a Ford Escape on lease and they did not have a brake service on the maintenance scheduled so never did it on that car either.
madmax1698
Montreal
2016 Civic EX Sedan
Nope. Never been touched by anyone since new. It looks really bad, but I'd say it's still safe to drive it like that. I plan on swapping the rotors and pads in the rear after this winter.
Gotch
Rob
2022 Si
My rears look like this too! I only get shake at 260kph light braking though.
Gotch
Rob
2022 Si
mis3
PT
Ontario
I go to the dealership next week for an oil change.
Let’s see what they say about the brakes.
REBELXSi
Señor Member
My SI now had 22K KM and I feel vibrations during brakes. My oil life is 30% left so I will bring in the car. I will ask them to check the brake.
I think 22K miles (regular driving) is too soon to replace the brakes, right?
With my previous car (MB), they recommended to replace the rotors together with the pads every time. How about Honda? Do you guys prefer aftermarket or Honda rotors/pads?
I've always just replaced both.
mis3
PT
Ontario
A follow up.
I went in for service A1 and for the vibrations in braking, they did the A9 brake service. Of course I complained about this A9 service and they said this is a Honda directive and the dealership has no say in this.
However, they did replace the front pads and rotors at no charge.
Picked up the car the next day and it was perfect.
