h3nyr
I like Motive Vacuum Bleeding Kits. They are relative cheap and looks heavy duty, but I don't think their master cylinder cap adapter isn't gonna fit on my 2017 Civic 4 door Sedan touring because the MC location is in a tight space. here is quote from their website
"Honda and Acura - Honda uses two size reservoirs. One reservoir is approximately 2.5" in diameter - that one uses the 1101 cap which comes with kit 0101. The other reservoir is about 3" in diameter. It uses cap 1119 which comes with kit 0119. You can use the 0119 on both size reservoirs, however the 0101 will only work on the smaller Reservoirs. Stock caps CAN NOT be modified to work with our bleeders. Please check that the brake fluid reservoir is easily accessible and that it is not under the cowl as the 0101 requires easy access to the brake fluid reservoir."
0119 METAL ROUND UNIVERSAL POWER BLEEDER LINK
0101 ROUND UNIVERSAL BLEEDER LINK
Any thoughts? Thanks in advance!
