Boost peaking at 8 Psi????
Weesawn
San Jose,CA
2017 Civic Si
Hey guys,
I don't have my boost gauge on very often, but today I had the urge to see what my boost levels were at. I'm aware that the average psi levels is around 17-18 for the SI, so I was quite shocked to see that I was barely hitting 8 psi. I know the dealership is an option to go to, but I want to see if I can fix it myself before going there.
So, what are the possible causes of this problem and how can I fix them?
Much appreciated!
8 psi at wide open throttle? :eek:
Weesawn
San Jose,CA
2017 Civic Si
Not wide open, but 3/4 throttle. I'm pretty sure it shouldn't be that low either at the 3/4 throttle, but then again I'm still new to this stuff.
civictrooper
Jonathan
Connecticut
2018 civic si sedan
Just had the same probably another member told me to check the throttle hose might be lose I don’t know how it got lose but was a little now hitting 16/17 hope this helps
Neps18Si
P-Low
Davie, FL
2018 Civic Si sedan (sold), 2019 Civic Sport Hatch CVT
I would get on it at 2nd to 3rd gear at over 3000rpm let the boost build and floor it...then if it still topping at 8 psi i take it to the dealer. Who knows maybe turbo can be bad lol. I work in a parts department and see weird parts getting changed. At Porsche we got a brand new 911 turbo S and the hydraulic stabilizer link was leaking already when doing the PDI.
Shit happens.
REBELXSi
Señor Member
Wouldn't have pics would you ?
RamrodSi
Josh
Johnson City, TN
2017 Honda Civic Si coupe
The boost is limited by power. Power target, not boost target. Some days you will see 17 psi and some days you may see 20 psi. Get a tuner and it becomes boost target.
REBELXSi
Señor Member
I know nothing about tuning so pardon. My ignorance but if you got ktuner can you just dial a boost target or do you need to get it tuned by someone that knows what they're doing? I wouldn't mind having an option to get 20psi on demand instead of when the car wants.
RamrodSi
Josh
Johnson City, TN
You can run a tune that is stock/19.5 or 19.5/23
dc2turbo
usa
civic,teg
8psi at wot is not normal at all if it's above 3000rpm. 75% throttle is WOT on this DBW throttle map
turbo dragon
Chad
Macon GA
SI X
Ive noticed mine wont get over 10psi also, I thought that was normal for factory. I will definitely be looking in to this
Blindeye_03
Cincinnati Ohio
'19 CTR - White
This
Also, if you are only part throttle, you wont see full boost pressure. Just floor it through 2nd or 3rd gear and if you are still seeing 8psi then thats not normal. You might have a popped hose on your intercooler.
