Blow Off Valve - Available Now !
Tags:
  1. Boomba Racing
    Boomba Racing Civic X Vendor
    Nov 30, 2016
    691
    417
    Wood Dale, IL
    2017 Civic Sport, 2018 Civic Type-R, 2010 Civic SI, 2015 Civic SI,
    #1 Boomba Racing, Jan 31, 2017
    Boomba Racing is very excited to bring you our Blow Off Valve for the Tenth Generation Civic!
    Available here: http://www.boombaracing.com/2016-honda-civic-blow-off-valve-1-5-turbo/
    Installation guide: http://www.boombaracing.com/content/CIVIC X - BLOW OFF VALVE MANUAL.pdf
    No aftermarket tuning required. Will work on stock tune or aftermarket tunes. This piece does not throw any check engine lights, does not cause any turbo lag, and does not make the vehicle stutter between shifts.
    Replace your factory BPV which is made of cheap rubber and plastic and known to rip and leak boost. This high performance VTA (vent to atmosphere) blow-off valve is precision machined out of aircraft grade billet aluminum. It features an internal brass piston design and is pressure tested to withstand up to 100psi, allowing it to compliment even the most aggressive turbo builds. Spring pre-load determines the pressure differential required across the piston before the BOV opens and releases the pressurized intake charge. Designed to be a replacement for the OEM bypass valve and is available in 4 different colors.
    Installation is simple (direct replacement to stock) and all necessary hardware is included.
    Available in your choice of color: Black, Blue, Red, or Pure Aluminum
    Sgtstaadanko thanked this.
  2. OP
    Boomba Racing
    Nov 30, 2016
    691
    417
    Wood Dale, IL
    Install guide added.
  3. OP
    Boomba Racing
    Nov 30, 2016
    691
    417
    Wood Dale, IL
  4. ethanmhanks
    ethanmhanks Project Blackout
    Jan 10, 2016
    247
    147
    Occupation:
    Finance Manager
    Roseburg, Oregon
    2016 Civic EX-T, 2015 Ram 1500, 1975 Corvette.
    Fast delivery! After work I might try and slap this baby on! Thank you for the goodies too!20170207_122841.jpg
  5. DrwMDvs
    DrwMDvs Senior Member
    Feb 26, 2016
    372
    335
    NE
    2017 WOP Civic Si Sedan, 2000 Honda Civic
    Bottle opener? Sweeet.
    SilverDyme and ethanmhanks thanked this.
  6. OP
    Boomba Racing
    Nov 30, 2016
    691
    417
    Wood Dale, IL
    Unboxing video!
  7. SilverDyme
    SilverDyme Senior Member
    Aug 2, 2016
    98
    38
    Bay Area
    2016 Honda Civic EX-T
    LMAOOOOOOO!!!!!!!!!!
  8. Flipdawg13
    Flipdawg13 Member
    Apr 18, 2017
    Chicagoland
    2017 Civic Hatch Sport Touring, 2016 Odyssey EX-L/RES, 2008 CBR600RR (still a Honda)
    Awesome, I might have to pick me up one of these!
    Boomba Racing thanked this.
  9. LeaveEarly
    LeaveEarly Senior Member
    Feb 27, 2017
    315
    76
    Civic HB LX HS
    Hi Boomba Racing,
    I am very interested installing one of these on my civic hatchback lx cvt. However I have some questions:
    1. Does installing one of these void the warranty?
    2. Given the car is almost computerized in function, would the lack of air that is expelled may cause confusion among the car's computer?
    Let me know
  10. OP
    Boomba Racing
    Nov 30, 2016
    691
    417
    Wood Dale, IL
    1- When it comes to warranty; in short, innocent until proven guilty. Certain dealers can be more picky than others when it comes to aftermarket parts. Some dealers are fine with mods whereas other dealers will not accept any mods. We always tell the customer to ask the service advisor first for what’s acceptable at any given dealership and if you have any doubts to return the car to stock form before bringing it in to a dealer. Furthermore there is a law called the Magnuson Moss Warranty Act that states in order for a dealer to deny warranty work on your car, they have to prove the aftermarket part you have installed caused your issue. For example if your window stops working and you have a cold air intake, the dealer is not going to void your warranty. It is illegal for a dealer to void your warranty for simply having aftermarket parts installed.
    2- The vehicle uses a complex method of MAP and MAF sensors to monitor what the vehicle is doing with incoming and outgoing air. The spring pressure we use in our BOV was carefully chosen so that the vehicle's operation is not negatively impacted from running this BOV. There is no stuttering, no increased turbo lag, and no check engine lights from running our BOV.
    BlackedoutFC1 thanked this.
  11. GAT305
    GAT305 Member
    Jun 11, 2017
    43
    48
    Occupation:
    EMT
    2017 CTR Crystal Black
    Boomba Racing,
    Is this BOV compatible with the 2017 Si's. After watching your installation video it looks the same as the Si engine bay.
  12. OP
    Boomba Racing
    Nov 30, 2016
    691
    417
    Wood Dale, IL
    Hey there,
    That'll work for you! We're just working on adding it to its own section on our website!
    GAT305 thanked this.
  13. grecocivic
    grecocivic Member
    Oct 7, 2017
    Greensburg PA
    Vinnie
    Honda Civic EX-T
    Any issues with idling with stock and no tune
