mash
- Mash
- Nov 26, 2018
- 15
- 17
- Chicago
- 2018 Civic Si
- #16
My engine was warmed up and it was right after i did a pull. ( i did bounce off the the rev limiter ). It cost around 4k to rebuild the engine or over 10k to get a new engine. I believe it would be better to just find a used engine and have it installed.Well... 50 to 70 could be anywhere between a bit under redline to nearly 9000 RPM. If you go to the dealer, they'd see if you have an over rev code in your ECU.
There's been a few here and there, as there are with all manual cars. If it survived the event and a valve didn't float and bend as it smacked a piston, it was probably ok and may very well have not contributed to the later failure.
Was your engine warmed up when you did the 2 step when the failure happened?
