Best fitment??
gva2984
Not just another Type R
Gabriel
El Paso
2019 Honda Civic Type R
Hi y’all, I’m still looking on wheels but no luck so far. The more I look into it, the more I get confused :dunno:. I want a flush fitment and with no fender roll or camber, even if I do a 1 or 2 inches drop. I’m pretty sure if Id lower my car, I’ll probably have to camber depending on the suspension but it’s the only way I will camber. Could y’all educate me with some fitments? Also, I’m not interested in any staggered setup. Thanks :thumbsup:
xxbodkinxx
Shane
Texas
2018 Civic SI Coupe
8.5 wide and 35-40 would give you flush fitment with no worries with rubbing etc. Ill be going 9.5 et40 with the expectation that ill need to run a degree or so of camber to eliminate any rubbing issues.
marktex
Mark
Canton Texas
2019 Civic Si Sedan
Could I run 18x8.5 +25 with the Si? Or would 50 fit better? Looking at a set of Enkei Tx5's for an Si Coupe.
+25????
Is this the look you want?;)
Honda Civic 10th gen Best fitment?? images
marktex
Mark
Canton Texas
2019 Civic Si Sedan
+25????
Haha yea, a bit new to aftermarket wheels and fitment but I may keep it around at the stock 18x8 +45. Other than maybe lowering it a bit i don't plan to do anything major right now.
xxbodkinxx
Shane
Texas
2018 Civic SI Coupe
Its not that bad. This is 18x9.5 et38 which would be the same as 8.5 et23
Honda Civic 10th gen Best fitment?? img_2850-
marktex
Mark
Canton Texas
2019 Civic Si Sedan
that looks really good! Just picked up a 2019 black Si Sedan today! Actually loving the stock wheels with the black color at the moment.
