Best aftermarket exhaust?
  1. spiikey1
    spiikey1 Senior Member
    Jun 20, 2018
    72
    Australia
    David
    Honda Civic RS
    Does anyone actually know if you go striaght pipe/one muffler delete/ resonator delete that you will lose or gain hp/low end tq?
  2. fist4064
    fist4064 Senior Member
    Apr 25, 2017
    93
    Ben Lomond, CA
    2017 Honda Civic EX-T 6MT Coupe, 2013 Nissan Frontier SV
  3. fist4064
    Apr 25, 2017
    93
    Ben Lomond, CA
    Do you have plans on releasing anything for the EX-T coupes? Please :)
  4. Vincent@27WON
    [email protected] Senior Member
    Nov 24, 2017
    1,515
    2,850
    Occupation:
    President, Founder, Racer, Enthusiast
    Vancouver, WA
    Vincent
    17 HBS, 18 SI, 18 CTR
    It's our hope to support all the trims and chassis but we are still far away from anything for that model anytime soon.
  5. peterletran
    peterletran Senior Member
    Apr 2, 2017
    158
    36
    Philadelphia
    2017 Civic EX-T Coupe 6MT
    Yea. Sorry. I take it back.
    I was fiddling with flashpro manager very quickly and couldn't find it when I posted that previous post.
    I guess I should put my catless downpipe back on, one of these days.
  6. James3spearchucker
    James3spearchucker Senior Member
    Dec 31, 2017
    146
    45
    El Paso, Texas
    James
    Yes, Honda is showing a 30 horsepower potential variance across the different models of Civics. These cars have high compression and good potential. From the lower trims with their smaller pipes and chambered mufflers up to the SI model with larger pipes and large chambered mufflers, power goes from 170-ish to 200, but when you take out the chambered mufflers and put in straight-through the engine finally wakes up, tone is improved, and the manual cars are easier to drive. The resonators are fine from factory but as part of smaller diameter pipes can restrict. The horsepower curve is shifted upwards definitely. You can follow the secret to better scavenging too by going from narrow pipes near engine to larger pipe and then reducer cone at tailpipe for max scavenging and horsepower potential.
  7. hawk02
    hawk02 Senior Member
    Nov 3, 2016
    1,235
    582
    Far away
    2017 Civic Si Coupe
    LOL, there will be NO increase in performance from a muffler/resonator delete, it is just for sound, catless DP there can be UP to 30hp but NOT from the exhaust.
  8. James3spearchucker
    Dec 31, 2017
    146
    45
    El Paso, Texas
    James
    2017 Honda Civic EX 1.5T: 174 HP, torque: 162 lb ft.
    2017 Honda Civic Hatchback Sport: 180 HP, 177 lb ft.
    2017 Honda Civic SI: 205 HP, 192 lb ft.
    What accounts for the power changes? A different tune, intake, and exhaust on the SI as well as exhaust turbine wheel. On the hatchback, a different exhaust alone. If you took a The EX sedan or hatchback and threw on a well-designed exhaust, you would be looking at 15-20 horses more and similar torque increases if not more. My hatchback feels like it's around 195 horses. The off-idle response is better and the breathing has dramatically improved. NO CHANGES TO DOWNPIPE OR FRONT PIPE
    With a increased boost, my power would be even higher.
  9. fabster22
    fabster22 Senior Member
    Jan 3, 2018
    139
    150
    Keller, Tx
    Fabian
    2018 Hatchback Sport 6MT , 2018 Accord Lx
    If you’re talking about a full turbo-back exhaust, maybe. The restriction is at the downpipe. :thumbsup: Unless you have dyno sheets to prove a cat back can give you 15-20 (Injen doesn’t count)
    hawk02 thanked this.
  10. hawk02
    Nov 3, 2016
    1,235
    582
    Far away
    2017 Civic Si Coupe
    Tuning, turbo and recommended fuel, nothing to do with deleting any part of the exhaust except if the cat is deleted
  11. spiikey1
    Jun 20, 2018
    72
    Australia
    David
    Honda Civic RS
    This was my understanding of the straight pipe. You only get sound.
    Muffler/resonator delete, you'd think there is more exhaust coming out faster so more power right?
    I'm most likely wrong. haha
  12. BoostedDreams
    BoostedDreams Senior Member
    Apr 15, 2018
    1,139
    666
    South East Florida
    Heisenburg
    2019 Type R, 2006 Mazda 6
    I thought that write up was sarcastic the entire time lol. I agree power is in the downpipe, especially under 400 horse. PRL tested this theory already.
  13. James3spearchucker
    Dec 31, 2017
    146
    45
    El Paso, Texas
    James
    PRL make and sell downpipes so don't ask them how much power a Greddy or Injen exhaust will make. Try again.
    Depending on your combination and parts, and depending on what RPM range you want to attack, a great exhaust system can be designed and built. The Honda cat is not as restrictive as other make of cats, and tuners such as VitViper have proven this. If you look at the stock cat you will see this. Now, no cat will help the turbo to spool faster but top end power will not be as affected. If you take the restrictive mufflers out and put straight through race mufflers you will help your top end flow and power output.
    It is one thing to Dyno test and show the results with many different combinations but this takes time. Saying something on a forum is not proof. Still though, I do not have any agenda besides sharing my results on my car as a member. You can take it for what it's worth or try different exhaust and intake options yourself. What I can tell you is that my Civic is breathing much better and is a cat versus the kitten it was before. Top end is way better. It's like a different car on the highway.
    Siiick and Myx thanked this.
  14. crxFITcivicBOY
    crxFITcivicBOY Senior Member
    Aug 9, 2018
    112
    95
    Michigan, USA
    I really want to get the GReddy exhaust for my 6MT Hatchback sport... I’m driving with the windows down and I can still barely hear the stock exhaust lol. With windows up it’s silent... Anyone have regrets with their Greddy SP?
  15. James3spearchucker
    Dec 31, 2017
    146
    45
    El Paso, Texas
    James
    Hi there. I think the answer depends on the end user because aftermarket exhausts all flow better than stock so it comes down to what kind of noise you like. The Hatchback Sport Greddy is a single muffler and offers far more sound than stock. If it ever seems too loud you can add a 14in Ultraquiet Vibrant resonator in the stock location. You will have 3 in exhaust going back for faster turbo spool and flow.
    Hopefully your question can get answered by someone with the Greddy because I have only heard the video clips. Good luck and let us know what you think if you get this one.
