alex.fk7
- Apr 4, 2017
- 13
- 23
- 0
- Connecticut
- 2017 Honda Civic Hatchback Sport
Anyone running BC Coilovers on their hatch? I have a few questions.
i do. shoot them my way!Anyone running BC Coilovers on their hatch? I have a few questions.
I installed them on my hatch. but when i go over a big bump in the road i hear a clanking noise in the right rear coil and can not figure out what it is. any idea?i do. shoot them my way!
can you by chance take a pic of the rear for me both sides. good thing the hatch is easy to get under the back. maybe something isn't tightened enough. the perches may not be connected and tightened together or something is loose so its moving aroundI installed them on my hatch. but when i go over a big bump in the road i hear a clanking noise in the right rear coil and can not figure out what it is. any idea?
i believe the rear and front are 2 clicks stiffer from the middle. im not sure though honestly. id have to check for ya later but somewhere near thereCan i ask for your damper setting?
I'm just having the problem finding my "perfect spot". If you able to find out that would be great :]i believe the rear and front are 2 clicks stiffer from the middle. im not sure though honestly. id have to check for ya later but somewhere near there
that is one sweet hatchi do. shoot them my way!
You’re about as low as I am, do you remember ur damper settings? I keep bumping the plastic in the front going over bumps. I don’t know if I should stiffen them up or just raise the front. I’m running a 8k front and 6k rear with the max low kit.when i was running no lock rings in back it would clunk, do you have at least one lock ring installed and plastic thrust washer installed over lock ring? for the front make sure you have preload on the spring so its not moving around and make sure lock rings are tight and sway bar endlink tight. Also check main allen head bolt that keeps shock attached to camber plate
No rubbing up front on bumps? What size wheels and tires are you running?my damper settings front and back are at the softest. I called bc and ordered custom rear shock cartridges, they go about 2 inches lower than the max low kit, also swapped out the 170mm max low rear springs for 145mm, I can take a picture of it if that would help you
