Axle shaft bearing leaking fluid
Si.R.Red
Westin
Texas
2017 honda civic Si sedan
Hey all, i had my car up in the air doing an oil change the other day and i noticed fluid leaking from the axle shaft support bearing, i have an appointment next week to get it replaced under warranty. Im wondering if anyone else has had this issue, and if it is a common issue on these cars?
Honda Civic 10th gen Axle shaft bearing leaking fluid 20190805_162938
choo
FL
'17 Hatch Sport 6MT , 1995 240sx
Wow I've never even seen one of those leak...its a thick greasy substance coming out I asssume? Its a sealed bearing so there should be some grease in there but probably not alot more than that...
warsaws
Here
Civicx
I see the same thing on mine when doing oil changes. I’ve not yet done anything about it. Please keep us posted.
I will post a picture of mine soon
Royal_Purple_Oil_Filter
Los Angeles California
2019 Civic Si Coupe
Any update?
eugeneli5354
Eugene
Vancouver
2017 Honda Civic LX 6MT
I found out yesterday. I have contacted Honda of Canada Manufacturing customer service.
I will post the update here soon
SpoolAndGo
US
2017 Civic Hatchback LX CVT
Do any of you have clunking sounds or feelings under the car? I think my seal is leaking as well and I hear/feel a clunk from around the pedal area when driving over cracks and bumps in the road.
eugeneli5354
Eugene
Vancouver
no i dont have that clunking sound.
it should be under the footwell on the passenger side
eugeneli5354
Eugene
Vancouver
Hi all,
Here is an update with my situation. The dealership admitted that the bearing was not packed properly. They have replaced the entire half shalf assy(13).
But, they made a mistake in the ordering of the part the first time and replaced (2) as well.
Honda Civic 10th gen Axle shaft bearing leaking fluid resource (1)
Honda Civic 10th gen Axle shaft bearing leaking fluid IMG_0910
IronFusion
Fred
Philadelphia, PA
2017 Civic Coupe EX-L
Hi all,
Wow. The before/after assembly mount... Looks better quality. Also different (guessing 2.0L) from @Si.R.Red 's Si or my CVT mount.
I also have an Axle related issue. A failing exhaust hanger too. I'm going to the dealership for recall updates and a re-up on interior protectant in the next month anyway. My issue doesn't look quite like the two pictured above.
https://www.civicx.com/threads/1-5l-cvt-cv-axle-leak.42674/
SpoolAndGo
US
I think I have this issue as well. Is there any chance this could cause a clunking/snapping noise when the front suspension moves up and down?
RonSwanson's
Mikey
Plainfield IL
2019 Civic Hatch Sport
I had the exact same problem!!
My engine shield pan had an oily substance leak in that same spot,but it wasn't thick like yours. and near the axle from the original poster, but they wiped it up and hasn't come back yet in 1500 miles.
RonSwanson's
Mikey
Plainfield IL
Interesting you say that, mine has this rubbing sound going over speed humps only when below 30 degrees F!
l0p3s22
South Carolina
VW Jetta GLI Autobahn
Same issue here. I was getting an oil change at the dealership today and they pointed it out. Right Axle seal is leaking. Luckily I have the extended warranty that is covering it.
The car is 3 years old with 24,000 miles on it.
My appointment to get the warranty work done is a week away. The dealership didn't seem to think it needed to be done right away but since it was covered they told me I should just have it done. Should I take it easy while driving or try to avoid driving until it's fixed? It wasn't clear to me how serious these types of leaks are.
