Anyone use regular gas in their Si?
  1. Dharmaboy
    Dharmaboy Senior Member
    Apr 14, 2019
    61
    Nash
    2019 Civic Si Coupe white
    sweet. Guess all we have to worry about is oil dilution and swapping out the oil ever 3-5k Miles
  2. amirza786
    amirza786 Senior Member
    Oct 4, 2018
    3,066
    2,945
    Occupation:
    Director of IT
    A
    2006 Camry SE V6, 2013 Toyota Sienna LE, 2018 Honda Civic Si (SOLD), 2010 Lexus IS 350 Sport
    Just follow the MM. Oil analysis on my last change after 7K of hard driving showed that I could have waited past 8K. Changing your oil every 3 to 5K is unnecessary, wasteful to the environment and doesn't help your wallet
    Siiick and jason510 thanked this.
  3. Jolavemma
    Jolavemma Member
    Sep 2, 2019
    Northern va
    Jacob
    2017 Civic Si
    Please explain more . What scientific method or opinion ?
  4. amirza786
    Oct 4, 2018
    3,066
    2,945
    Occupation:
    Director of IT
    A
    #109 amirza786, Sep 18, 2019
    Sure, let me start with the question: Would it be bad to go back and forth between 87 and 91? The scientific answer is NO. The reason is that 1) Premium is recommend and not required for this car and 2) when using Regular or Premium, the cars ECU will adjust timing based on what type of gas has been added in the tank by either pulling or advancing timing. This is documented, and I have seen it myself in data logs from when I did runs. You would see this under knock control or k.control. The reason for this is 87 octane is more volatile and can pre-ignite causing knock or ping in higher compression/turbo charged engines
    An opinion would be making the statement that switching between 87 and 91 is bad, the reason being is first of all its not correct and secondly there is no data to support that, from Honda or anywhere else. The person feels for whatever reason that switching back and forth would hurt the car without actually experiencing it being damaged.
    That being said, Premium is the recommended fuel, the car will perform better on it, and you will get 15 more hp, which is a good reason to use it.
    One caveat I would like to point out is if you are tuned, that changes the equation, as in most cases the car was specifically tuned for premium (Ktuner base maps, TSP Stage 1 tune etc)
  5. Jolavemma
    Jolavemma Member
    Sep 2, 2019
    Northern va
    Jacob
    2017 Civic Si
    good to know ! Thank you very much for taking the time to explain it brother
    amirza786 thanked this.
  6. amirza786
    Oct 4, 2018
    3,066
    2,945
    Occupation:
    Director of IT
    A
    You are very welcome!
  7. j9lazur
    j9lazur New Member
    Dec 27, 2019
    Bucks County PA
    Janine
    2020 Civic Si Sedan, 2005 Element EX AWD manual transmission
    I'm a new 2020 Si owner and am still on my first tank of gas. I found this old thread and want to add new info with this screen grab from the 2020 manual. It's similar to what has been said but a little more specific. If your car has sport mode, which the Si does, the manual is specifically recommending 91 octane or higher and cautioning against anything less than 87. Of course, if you never use sport mode, perhaps not an issue. Dunno.
  8. tinyman392
    tinyman392 Senior Member
    May 21, 2018
    1,205
    611
    Illinois
    Marcus
    '18 Civic Type R (RR)
    The sport mode designation is talking about cars with sport mode vs sport mode itself (note how they say models with sport mode vs just sport mode, they are referring to the model vs the mode). So if you have a car with sport mode, then they recommend 91, minimum is 87, and anything lower than 87 can cause damage to the motor. The mode you're driving the car in doesn't matter in this case, it's the fact that it has the mode available. IE, if you're driving in normal mode using 85, you can damage your motor, but 91 is still recommended in normal and sport modes. I'm assuming they are using the sport mode designation to group together the following trims: Si coupe, Si sedan, Sport coupe, Sport Touring coupe, Sport sedan, and Sport Touring sedan instead of listing those 6 outright.
    TL;DR: The sport mode is used to indentify the model/trim of the vehicle not referring to the mode itself, rather a car having said mode. Using < 91 octane in normal mode may still cause knock, using < 87 octane in normal mode will cause damage.
    j9lazur thanked this.
  9. AegeanT
    AegeanT Senior Member
    Apr 29, 2016
    507
    398
    Occupation:
    Health Care
    London, ON, Canada
    2019 Honda Civic Si, 2016 Honda Civic Touring (sold)
    Dealer put in regular on my first tank. Ran 89 midgrade for my 2nd/3rd tanks, and then just started to run premium on my 4th (current) tank after noticing the prices come down.
    I'll just say that I notice a decent difference between when I got the car with regular and on this tank with premium gas that I put in. It feels smoother and throttle response I find is a bit better.
    So as long as prices are reasonable, I will always put premium in. It's good to know (and I confirmed with dealer along with my manual) that running regular is fine if I have to though.
  10. j9lazur
    j9lazur New Member
    Dec 27, 2019
    Bucks County PA
    Janine
    @tinyman392 thx, makes sense--there's a manual for sedans and one for coupes, each including all trim levels
  11. tinyman392
    May 21, 2018
    1,205
    611
    Illinois
    Marcus
    I wasn't sure if Honda split the Sedan and Coupe ones, but it makes sense that they would.
  12. xbbnx
    xbbnx Senior Member
    Jun 21, 2017
    712
    664
    Houston TX
    2017 Honda Civic Si (Current), 2015 Honda Civic Si (Past)
    #117 xbbnx, Dec 29, 2019
    The Sport Sedan/Coupe do not recommend premium and are only required to use 87/regular gas. The only "Sport" designated Civic that recommends premium are the Sport Hatches. And also there is no such thing as a Sport Touring Coupe/Sedan, its just the Sport.
    tinyman392 thanked this.
  13. REBELXSi
    REBELXSi SeƱor Member
    Aug 12, 2018
    1,674
    1,468
    S/E PA
    '18 Si Coupe
    8 pages on this topic :rofl:
