Anyone use regular gas in their Si?
  1. AUGM1
    AUGM1 Senior Member
    Apr 22, 2019
    69
    US
    SI
    Just wonder how the performance and gas mileage are affected.
  2. Honda_RacerX
    Honda_RacerX Senior Member
    Jul 1, 2019
    541
    386
    2001
    2019 Si
    Itll run like poop.
    fretcrazy, j_si19, Jay19Si and 2 others thanked this.
  3. Masked
    Masked Senior Member
    Jul 12, 2019
    103
    60
    Quebec, Canada
    Jos
    '18 Civic Si Coupe
    Oof big no for me, I'm on 94 and nothing less. This platform performs super well on higher octane gas, don't go below 91.
    Honda_RacerX, Jay19Si and Old George thanked this.
  4. REBELXSi
    REBELXSi Señor Member
    Aug 12, 2018
    1,674
    1,468
    S/E PA
    '18 Si Coupe
    I've done it over a full tank of highway miles and it was fine but I was just cruising the whole time. Didn't see a hit on mpg.
    I wouldn't do it if I was going to drive in a... Spirited fashion.
    jopale, MutatedMango and Jay19Si thanked this.
  5. Jayceegee
    Jayceegee Senior Member
    Mar 20, 2019
    182
    211
    United States
    2019 civic si
    Uhhhh, no on regular gas
    Jay19Si and Honda_RacerX thanked this.
  6. Bluecoupe777
    Bluecoupe777 Member
    Aug 3, 2019
    98275
    Eric
    2018 Civic Si Coupe
    Just my two cents..Honda recommends premium in the turbocharged Si for a reason. I would never recommend putting regular in a car that is designed to run on premium fuel unless you want to risk some type of future repair work. Also, I'm pretty sure it says either premium fuel only/required or at the very minimum, recommended right inside the fuel door as a reminder. I'd also think this could potentially void the warranty on the engine should something go wrong from running 87.
    silverblip thanked this.
  7. tinyman392
    tinyman392 Senior Member
    May 21, 2018
    1,205
    611
    Illinois
    Marcus
    '18 Civic Type R (RR)
    Required fuel is regular unleaded with premium recommended. So using regular fuel won't void the warranty, but it'll pull timing and cut power to adjust for the different fuel. Basically with the Si (and Type R), the engine is designed to run on premium, but can run on regular as well with an ECU that will adjust timing for the fuel that is in it.
    peterZ, exit2302, MutatedMango and 6 others thanked this.
  8. Gino27
    Gino27 Red Rocket
    Dec 18, 2018
    82
    Occupation:
    Student
    2020 si coupe
    Sometimes I put 87 in it just by habit. The power doesn't feel as smooth as with 93, but a lot of people would be totally fun with just regular.
  9. REBELXSi
    Aug 12, 2018
    1,674
    1,468
    S/E PA
    '18 Si Coupe
    They definitely won't void the warranty for using regular. It says premium recommended.
    If you want the full potential of the engine, stick to premium.
    You could probably go far on regular gas and Honda fluids but this is a forum of mostly enthusiasts so there's a lot of synthetic oil from boutique manufacturers and definitely no regular gas.
    TheComebackKid and MattyNice thanked this.
  10. MattyNice
    MattyNice Senior Member
    Jun 5, 2018
    345
    268
    Charlotte, NC
    Matt
    2018 Honda Civic Si
    Yeah, it says “recommended” I believe for cars with sport mode. I just figure I bought the car for the performance so may as well use high Tess. I have thought about using 87 at times but even my cheap *** has yet to do it.
  11. pinhead66
    pinhead66 Senior Member
    Jun 6, 2019
    87
    42
    Bay Area, CA
    2019 Civic Si Sedan, 2018 Odyssey EX-L
    My first tank from the dealer was 87. After that nothing but 91. If you drive it conservatively all the time im sure 87 would be more cost effective. But since the gas mileage is so great theres no reason to skimp.
  12. LittleturboSi
    LittleturboSi Member
    Apr 4, 2019
    2019 Civic Si
    Yes I did that on purpose few times to test. The performance is affected by using 87, but not by much as I thought relatively (vs 2015 Si). The mileage is about 6-8% worst for the same type of driving.
    For my 2015 Si, I could tell the difference right away even between 89 and 91.
    MutatedMango thanked this.
  13. Monocacy
    Monocacy Senior Member
    Aug 12, 2017
    111
    105
    Maryland
    Bruce
    2017 Civic Si sedan
    Yes, that is about what I found. Modern engines have knock sensors so if your engine begins to knock under load the computer will adjust the timing, reducing knock but also reducing fuel efficiency. Increased fuel efficency for high-octane gas partially offsets the increased cost of high-octane fuel.
    Also, knock sensors don't adjust timing until they hear knock. Over time knock increases wear and tear on your engine.
    For me it does not make sense to buy a sporty car and then not give the engine the fuel needed to perform as designed.
    repeet and MutatedMango thanked this.
  14. ltrinh
    ltrinh Senior Member
    May 20, 2018
    129
    50
    Temecula, CA, USA
    Larry
    2018 Civic SI Coupe
    Since dealer had 87 in the tank, I used 87 for the first 1k miles, then 91 (there is no 93 in SoCal) for the next 1k miles, back to 87 for the next 1k miles. Obviously this was for testing. 87 performed slightly worse in MPG, but not by much, as expected.
    91 is better for the engine, more fun, and MPG. Enough for me to stick to 91 ever since the first 3k miles testing.
  15. maggs_10thgen
    maggs_10thgen Senior Member
    Aug 9, 2019
    512
    400
    New York
    2019 Civic Si Coupe Old whips: 2005 RSX Type S, 2015 Civic Si Coupe, 1998 Integra GSR Green, 1998 Integra GSR Red
    Premium fuel is very important in a turbo charged vehicle. You want to avoid detonation.
