HBKEAZY!
How much does those springs bring it downI’ve decided to put some 245/35/20 on stocks, everything cleared, no rubbing what so ever. I’m lowered on Swift’s as well!
Good stuff. Do you have any pics of the car from a distance so I can see the drop w tires?
It’s about a 1 inch drop.How much does those springs bring it down
Do you think a 40 profile will fit under?? like a 245/40R20It’s about a 1 inch drop.
Are you lowered on Swift’s? It’ll rub if you go 245/40 on turns. I had the shop test fitted some sizes to see if it’ll clear and so far the ones that cleared for me was 245/35.Do you think a 40 profile will fit under?? like a 245/40R20
No I’m stock, where exactly would it rub? Did you try a 245/40 or a 255/40Are you lowered on Swift’s? It’ll rub if you go 245/40 on turns. I had the shop test fitted some sizes to see if it’ll clear and so far the ones that cleared for me was 245/35.
Tried both on Swift’s, it rubs on the inside front fender when you turn the wheel/hit a bump. You’re stock height so you should be fine. With stock height I’d prob go 245/40, but that’s just me.No I’m stock, where exactly would it rub? Did you try a 245/40 or a 255/40
Do it ever touch or get close to the strut?Tried both on Swift’s, it rubs on the inside front fender when you turn the wheel/hit a bump. You’re stock height so you should be fine. With stock height I’d prob go 245/40, but that’s just me.
Yes. Having had them back to back, the AS3+ is much better in the twisties.Is the Pilot Sport AS3 better in that regard?
Have you considered a different size? Like 255/30, 245/35, or 255/35. You might have more options with these.i found these but everyone is out of stock if anyone finds them please let me know
Not bad! That's what I'm looking at getting too..So I just went ahead and called a firestone tire shop near me, as my dealer didn’t want to order 255/35 for the oems. I’m paying 840 OTD that includes to mount and balance and alignment (if needed) I had an alignment done about a month ago when I had hit some pot hole and blew both my front and rear passenger tires. Other than that, road hazard are included for the life of the tire, prorate the tire depending on the thread. they will also patch it up for free and that is at any Firestone. I went with the fire hawk Indy 500. Will review and upload pics once they are installed. Also there’s a $60 rebate.
