fk8jon
- John
- Dec 10, 2017
- 6
- 133
- 146
- MA
- 2018 Civic Type R
Link is dead can you please re upload?2016 Honda Civic Sedan - Side Mirror Glass Removal
Tools Required: -Flat blade screwdriver
The removal of 2016 Civic mirror glass from the mirror assembly it is affixed to, seems more involved and somewhat more delicate than the examples I found on YouTube for previous generation Civic mirror assemblies.
Step One:
Adjust the mirror so it pointed up and all the way toward the car. This would be all the way up to the upper right corner for the drivers mirrors and all the way up to the upper left for the passenger side mirror.
Step Two:
Locate the white tab that should be exposed behind the lower outside edge of the mirror. It is inset a bit should be visible.
Step Three:
Insert a flat bladed screwdriver just between this tab and the back of the mirror and twist (turn) the screwdriver. This should begin to release the set of tabs/notches holding the mirror in place.
Step Four:
Continue to insert the screwdriver a small amount and repeat the twist. Continue in the same fashion from the bottom lower corner of the mirror to the upper inside corner. At some point you should feel it really begin to pop loose. Gently pull the mirror loose and fold it up to the inside corner of mirror where you can remove the power leads to the heated mirror.
Link to PDF with pics:
https://dl.dropboxusercontent.com/u/6340909/2016 Honda Civic Sedan - Side Mirror Glass Removal .pdf
