Anyone else having paint peal off their break calipers in the front?
Harlaquin
2017 Type R and a beater ford focus
So yeah that is happening. Went to dealer and they of course tried to blame me right off the bat. Well you are racing your car and super heating the brakes... UM no. Its a daily driver. They they tried to say it was the soap I was using to wash it. Um again no I use a PH neutral soap. Then they flat out said they wouldn't fix it wasn't a warranty item. So I point out it is a bumper to bumper warranty and the brakes are between the bumpers. Then they said after review they still wouldn't fix it as its normal wear and tear. WHAT!! Brake paint falling off is normal wear and tear... Damn I hate dealers. So now I have a case open with Honda. And Im about to send a photo and email to Brembo to ask them if they feel its normal for their paint to fall off the caliper.
I told dealer I know people who do track this car and their paint isn't falling off.
Cant see real well in this pic but 3 weeks ago was a tiny spot. In a month or so will be whole caliper.
Honda Civic 10th gen Anyone else having paint peal off their break calipers in the front? 20190618_122211
racer
Dave
Virginia
2018 Civic Si sedan.
Its brakes , not breaks. Guess that's why the dealer couldn't give you a break. That said. Sorry about the paint finish failure. Maybe ask Brembo to fix it ? Good thing its "just a civic" :rofl:
Harlaquin
Harlaquin
SO Anyone other then smart asses actually have the issue?
ez12a
CA
18 CW Type R
Happens when brake fluid weeps out of the brake caliper and isn't cleaned. Have you or someone done any brake bleeding or flushing through the caliper?
Or possibly ran over/got splashed on with some damaging chemical.
Happened on my '04 TL with brembos. Happened enough on Mitsu Evos they have a TSB for it:
https://testing-public.carmd.com/Tsb/Download/86213/520057977
Harlaquin
Harlaquin
No not that im aware of. Car only has 12500 miles on it. Have not done any work with the Brakes.
CTR1633FK2
Netherlands
Civic Type R Fk2 + Civic Type R Fk8
Do you use wheel cleaners. They are very aggressive against paint.
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
its a common problems with brembos.
Evos had that problem, Jeeps have that problem, STIs has had that problem.
I know some people have gotten them replaced under warranty. Really just depends on the dealer you go to i guess.
Harlaquin
Harlaquin
Try another Honda dealership.
Some are easier to persuade than others when it comes to warranty work.
Problem is next nearest dealer is 70 miles away.
SBPerformance
Steph
2003 Evo, 2003 350z, 1998 CRV, 2019 Civic Type R
I had this issue with my Evo, Mitsubishi warrantied and replaced both front calipers. I have heard of others having this issue with their civics, I haven't yet though and I track mine haha *knock on wood*
SixxSpeed
Western Canada
Civic Type R
I think it's just shitty Brembo clear coat on the calipers. It chips from road rocks. Water gets in, with likely a combination of heat cycles and causes the clear to start peeling.
Happened on my TL with Brembos also... And it never lost brake fluid randomly, as someone else suggested.
100% it should be warrantied.
ez12a
CA
18 CW Type R
if you're referring to my post, didnt say that it randomly loses brake fluid. It can happen when someone does a fluid bleed or flush and not clean the screw area well enough afterwards. Hence the linked TSB from Mitsubishi about the exact thing.
Instead of going to a different dealer further away, try corporate instead?
DeVo
Austin, TX
2019 Civic Type R #21399
this happened to my buddy. he had it covered under warranty and warned me to check mine. mine still look fine at 8,500 miles
17CivicTypeR_Brian
York PA USA
I had this happen on one caliper. Took it in, gave some pictures, and they fixed it back in May.
