Anyone else have issues with tunerview on their head unit disconnecting?
  1. Honda_RacerX
    Honda_RacerX Senior Member
    Jul 1, 2019
    541
    386
    2001
    2019 Si
    I did the Honda hack and installed tunerview a few weeks ago. My issue is that it keeps disconnecting. It will stay connected for about 20 to 30 seconds then disconnect and freeze, then reconnect, then disconnect, etc. Its been like that since I installed it.
    When I use the app on my phone I do not encounter this problem as it stays connected.
  2. gtman
    gtman Senior Member
    Oct 27, 2015
    6,419
    7,198
    Occupation:
    CivicX addict
    U S of A
    2017 Cosmic Blue Civic EX-L
    When I had Hondata, their app was flawless with Honda Hack. With Tunerview, it simply won't connect or stay connected at all. Thankfully, I have the V2 and use that instead.
    Honda_RacerX and EdwarDallas thanked this.
  3. 86salmon
    86salmon It's Hedley, Hedley Lamarr!
    Sep 26, 2018
    696
    749
    SC
    2018 Civic si sedan 2001 Nissan Frontier
    Issues all of the time on my phone. Kindle fire hooks up pretty well
  4. EdwarDallas
    EdwarDallas Senior Member
    Oct 23, 2019
    118
    51
    Dallas, Texas
    Edward
    2020 Civic Si Sedan, 2016 HRV MT-6, 2015 Civic Si Sedan, 2010 Civic Si Coupe, 2004 Civic Si (EP3) AKA The Black Egg
    Mine (In my 2020 Civic Si Sedan) has an issue with initial connection where I have to unplug and then replug it in for it to be detected by Bluetooth. I usually do this right after I start my car so I don't have to fiddle with it again. But I feel each time it just makes the K-tuner unit a little less likely to connect well the next time or it degrades it fitment-wise.
    If I switch to my LaneWatch camera and then back, or out of TuneView for anything else (Change the radio station, use Pandora or Waze app--whatever else), often times it does not reconnect or stay connected in the background. Then I have to unplug it and replug it again WHILE DRIVING for Bluetooth to detect it and usually I have to swipe and have it re-detect the Ktuner unit.
    It's a Pain In The Ass.
    Frustrating.
    It should maintain it's Bluetooth connection in the background, I think.
    Edward
    Honda_RacerX thanked this.
  5. JT Si
    JT Si Senior Member
    Mar 17, 2019
    418
    315
    Willamette Valley
    JT
    2018 MSM Civic Si
    Yep, me too. Very aggravated. I've minimized the effect by tweaking the Bluetooth retry delay and count but it still frequently continuously reconnects. Also frequently it will stop reading from the ktuner.
  6. joshhjackson2112
    joshhjackson2112 Senior Member
    Jul 3, 2018
    657
    380
    Raleigh, North Carolina
    Josh
    18' SI
    My tuner view freezes up too. Sometimes when it connects, all the gauges read 0. I can usually pull the menu from the left of the screen to press connect. Then I will have to scan for device. Select the ktuner Bluetooth when it pops up and hope it connects. I often have to do this several times before it gets right.
  7. JT Si
    JT Si Senior Member
    Mar 17, 2019
    418
    315
    Willamette Valley
    JT
    2018 MSM Civic Si
    This, too. If I'm lucky, turning the lanewatch camera on and off will trigger it to connect without my having to fumble around with the headunit but sometimes it's just not enough.
    I wish there was a better, more reliable option for an app. I don't want to keep a phone, tablet, or ktuner v2 in the car to add a theft risk.
    joshhjackson2112 and Honda_RacerX thanked this.
  8. Aguirre129
    Aguirre129 Member
    Jul 23, 2019
    26
    Occupation:
    Production Supervisor
    NC
    Cristian
    2018 Honda Civic Si
    Mine does on a rare occasion. If you have Honda Hack (cant remember if you have to pay for the pro) you can map your buttons to switch to different apps on your screen. I have my up arrow set to Viper4Android and my bottom to TunerView. When it freezes I simply click on my up to change apps and then down to change back to Tunerview. This makes it reconnect without having to disconnect the device from the OBD2 port or having to mess with the screen while I am driving.
