Any ideas? Cyclic "Purr" accompanying Direct Injection ticking
  1. Suhrcooper
    Suhrcooper New Member
    Dec 16, 2019
    Blacksburg, VA
    Cooper
    2019 Civic Type R CW
    Hi all, I have been noticing this new sound coming from what sounds like the engine. The best way I can describe it is as a cyclic purr that happens while idling and while driving. The duration and "wavelength" fluctuate. I notice it the worst when I have just pulled in after driving and let it idle in the parking lot. Very audible from inside the cabin. I have attached a video to hopefully help out. The last 10 seconds of the video provide the best example
  2. afranzen2113
    afranzen2113 Member
    Oct 6, 2019
    2006 civic
    I just noticed mine doing this too. 2019 with 4069 miles.
  3. CDNTyper
    CDNTyper Member
    May 27, 2019
    Orillia Ontario Canada
    Travis
    2018 FK8 1999 turbo EK
    That’s strange. These motors are noisy with the direct injection. Is it worse with fan or Ac on? Engine cold or warm? Sounds almost like something vibrating against plastic but hard to hear
  4. alpinefd
    alpinefd Member
    Jan 5, 2020
    Walnut
    2019 Civic Type-R
    mine is making that same fast ticking buzzing noise, 150miles 2019 CTR.
    it appear to get louder with quick throttle inputs.
    anyone else have the same issue?
  5. leehom
    leehom Senior Member
    Jun 17, 2017
    224
    125
    under your bed
    Honda, back at it again
    My CTR started making this noise recently too. 4,500 miles.
  6. alpinefd
    alpinefd Member
    Jan 5, 2020
    Walnut
    2019 Civic Type-R
    has any of you taken this to the dealer? did they have any solution?
  7. IronFusion
    IronFusion Senior Member
    Nov 13, 2016
    497
    162
    Occupation:
    Software Developer
    Philadelphia, PA
    Fred
    2017 Civic Coupe EX-L
    Believe the
    That ticking is not an issue. It happens on the 1.5L too. Believe it's injector/tappet sounds.
    The OP's sound is interesting--sounds like exhaust pipe vibration or pumping sound. You could check the clearance of the front pipe and engine.
    If you get the car up to temp and drive around when it is warm-ish outside, no climate control on whatsoever, does it still make the sound?
  8. BogdanM
    BogdanM Senior Member
    May 28, 2018
    197
    101
    Romania
    Bogdan
    2018 Civic Sport Plus 1.5 MT
    The ticking is clearly the injectors working. Direct injection system is loud, both the high pressure pump and the injectors, as the sistem works as a much higher pressure (~200 bar).
  9. omar0123
    omar0123 Senior Member
    Apr 21, 2019
    485
    190
    Puerto Rico
    Omar
    2019 type r
    These honda DI engines are quiet next to other brand engines check out hyundai those sound crazy loud thats the nature of the direct injection engine
  10. NMEDRAN7
    NMEDRAN7 Member
    Jan 9, 2020
    20901
    nelson
    jeep wrangler 2003 SE, Honda Civic Type R 2019 RR
    Anything like this?
