Any aftermarket bypass valves?
squshy7
Pittsburgh, PA
Civic ST
Title says it all..
I know BOV's are not recommended, but wondering if an aftermarket BPV would still make the "woosh" more pronounced.
I know boomba was at some point developing one but it appears that's not going anywhere soon.
F30anderson843
Justin
Bluffton, Sc
2018 Civic Type R, 2014 BMW 335 EWG
Title says it all..
With Ktuner turn the boost up. The “woosh” is more pronounced then.
17siturb0
U.S North east
2017 civic si sedan, 2006 civic si coupe
Title says it all..
No.
Title says it all..
Do you have an aftermarket intake yet? They help bring out the sound a good bit.
123sillyboy123
2019 CTR
Has anyone try this? It mount onto the stock BPV and said will produce BOV sound.
TORQUE Solution BOV Sound plate
I wonder if this will cause the same problem as how BOV does on civic x??
Please advice.. thank you
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
R4y30n
WA
2018 Civic Si Coupe
I wonder if TurboSmart or anyone else will make replacement valves down the road, the high-boost guys will probably need them to prevent leaks.
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
PRL's turbo kit for the 10 gen civic's will use a TurboSmart 34mm Kompact Plumb Back Recirculating Bypass Valve
