Ansix Auto
- Greg
- Jan 13, 2020
- 5
- 39
- 16
- Vancouver, BC
- 2017 Civic Type R, 2017 NSX
Improve your braking performance, extend the life of your brake components, and make your braking system safer. Our titanium brake pad shims are an excellent and inexpensive way for managing your brake heat. They fit between your brake pad and brake caliper pistons to form a thermal barrier that protects your caliper and fluid from excess heat.
Our titanium brake pad shims are made of are precision engineered and cut 0.5mm 6Al-4V (Grade 5) Titanium. This material offers the lowest thermal conductivity of any titanium. In addition, we’ve applied a ceramic thermal barrier coating to further prevent heat transfer to the brake caliper, pistons and fluid. The coating used for these shims is the same as what is used on high performance pistons.
These fit the majority of the OEM Honda Brembo calipers like those found on the 2017+ Civic Type R and other manufacturers like the Subaru STi and Mitsubishi EVO. Currently only available for the front brakes. The fronts take the brunt of the braking heat and are usually the first to fade.
Free shipping to the US and use coupon code ANSIXAUTO15 for 15% your purchase! You can place your order here:
https://ansixauto.com/titanium-brake-pad-shim-set-acura-ford-gm-honda-saab-subaru-toyota-volvo/
