Amsoil Synchromesh vs. Motul Gear 300 LS 75W-90
  1. Tothemax
    Tothemax Member
    Sep 3, 2019
    NYC
    17' Civic Si Sedan
    Hi,
    I've probably read every post on the MTF fluids between multiple forums. I've narrowed it down to Amosil Synchromesh & Motul Gear 300 LS. I'm leaning towards Motul because i feel everything from Europe is made with much higher standards. I've got the Motul engine oil on hand already and would like to replace my MTF when i change out to the SS clutch line. I haven't seen much info on the Motul MTF though, anyone have experience?
    2017 Si Sedan w/ 12k Miles.
  2. turbociv910
    turbociv910 Senior Member
    Jun 25, 2019
    125
    103
    wilmington nc
    taylor
    19 SI, 99 ex b20v
    amsoil mtf is great
  3. CastorX
    CastorX Member
    Jul 8, 2019
    35
    Occupation:
    Automotive Test Engineer
    Germany
    Balázs
    Civic 1.5 Turbo Sport Plus
    So, in the US you have to change the transmission oil every 12k miles?
  4. OP
    Tothemax
    Tothemax Member
    Sep 3, 2019
    NYC
    17' Civic Si Sedan
    No, i bought the car used. Not knowing the previous owners driving habits and maintenance in general, i prefer replacing all fluids. This way i know exactly when the next change should be.
  5. CastorX
    CastorX Member
    Jul 8, 2019
    35
    Occupation:
    Germany
    Balázs
    Ok, I see. Btw I think the official change period for MTF in the EU is 120.000 km = 74.000 miles. I think it's a bit much, but. Honda knows it better, at least I hope they do.
  6. WOPSiWOT
    WOPSiWOT Senior Member
    Nov 23, 2017
    479
    404
    Southeast
    2017 Civic Si Sedan
    The Amsoil is 5W-30, the Motul is 75W-90. The Honda OEM is 5W-30. Use the Amsoil would be my recommendation. I use Motul 8100 engine oil, but used Amsoil MTF because it replaces Honda OEM (says so on the bottle). Honda uses low viscosity MTF and I would be worried running such a dramatically different viscosity oil (as the Motul).
  7. OP
    Tothemax
    Tothemax Member
    Sep 3, 2019
    NYC
    17' Civic Si Sedan
    I understand what you're saying, but the oil grades aren't that different. SAE engine & SAE gear oil use different grading system. When comparing these grading systems, both oils fall roughly within the same spec, "roughly". I'll likely go with Amosil, because i have used it in the past and have experience with it. I was just curious about the Motul MTF because the Engine oil is so highly recommended for our engines.
  8. zhendexing
    zhendexing Senior Member
    Aug 26, 2018
    102
    107
    Chicago
    Dee
    2018 civic si coupe
    What did you end up getting? I bought some motul 300ls for my 18si, temp dropped to 30s F last night, and the gear box felt weird this morning when I drove it, it was hard to get into 1st and 2nd, but everything was fine when it’s warmed up. The reason I bought motul is because I read 27won’s blog and motul is available on amazon,(AMSOIL could be only purchased through their wevisite) anyway, Im gonna switch to AMSOIL mtf
  9. OP
    Tothemax
    Tothemax Member
    Sep 3, 2019
    NYC
    17' Civic Si Sedan
    I went Amsoil for the MTF, Motul for the engine oil. Amsoil mad a HUGE difference, everything is smooth and i can finally go into reverse without having to go into a forward gear first...
    zhendexing thanked this.
  10. Vincent@27WON
    [email protected] Senior Member
    Nov 24, 2017
    1,422
    2,692
    Occupation:
    President, Founder, Racer, Enthusiast
    Vancouver, WA
    Vincent
    17 HBS, 18 SI, 18 CTR
  11. EP3R-T
    EP3R-T New Member
    Oct 29, 2019
    2018 WOP Si Sedan
    I'm in the same boat boat as the OP, just picked up an '18 SI and was looking to change fluids so I have a fresh starting point. I was going over the Amsoil information on their website and found this under the applications section:
    "Replaces Honda* Genuine MTF fluid for manual transaxles and Texaco* MTX fluid. Not for use in engines, hypoid rear axles, limited-slip or wet-clutch applications."
    I would hope they're referring to viscous LSDs and not mechanical. I would like to run this MTF, but not if I'll have an issue down the road, no pun intended.
  12. WOPSiWOT
    Nov 23, 2017
    479
    404
    Southeast
    2017 Civic Si Sedan
    Yes.
