Amsoil Synchromesh vs. Amsoil 75w-90 MTF
Which gave you better results?
  • Total voters
    39
BoostedSiCoupe
Cesspool
2019 Civic Si
  • Banned
  • #1
have any of you used amsoil's synchromesh? and if so how does it compare to their 75w90 mtf? how does it compare to GM's (ac delco) synchromesh friction modified? Which one gave you the best results.
while i have pretty extensive experience with amsoil mtf and gm SM, i have never used amsoil' s synchromesh. i know amsoils mtf really sucks in the frigid winter temps.
*Edit: this can apply to your R or any previous Honda youve owned*
diakonia
Alan
Richmond, VA
Civic Type-R, Accord, CRV
I took my CTR to my local Honda dealership along with Amsoil Synchromesh transmission fluid for a change out. They told me I would void my engine warranty if I did it, so I didn’t do it.
BoostedSiCoupe
BoostedSiCoupe
Cesspool
2019 Civic Si
  • Banned
  • #3
lol at stealerships. if you look at your car funny theyll try to void the warranty
Lust
Michael
Bay Area
2019 Champ White Type R
What type of climate are you typically in? Will the car see track use at all? In most cases a 75w-80 gear oil is recommended. I'd say Honda MTF is sufficient.
Hayabusa160
The Master
Matthew
New jersey
Civic type r
honda mtf is very thin i dont think 75w 90 is a good match for it.
i just got some torco rtf
BoostedSiCoupe
BoostedSiCoupe
Cesspool
2019 Civic Si
  • Banned
  • #6
does anyone know what is thinner between Amsoil Synchromesh and honda oem mtf? or are they the same?
i know the amsoil 75w90 mtf is pretty thick thats why it sucked so bad in the very cold temps.
Lust
Michael
Bay Area
Honda MTF is still thinner
AREA
Houston, TX
18 Civic SI coupe
What amsoil are you guys using? The synchromesh says it is not for lsd
Hayabusa160
The Master
Matthew
New jersey
Civic type r
honda mtf is like 10w 30 its very thin.
im using torco rtf is notchy when its cold but once its warmed the shifting is like butter.
tylermmorton
Tyler
Atlanta, GA
Civic Type R #1362
I can 100% vouch for the synchromesh fluid. I would often get second gear lockout and end up grinding pretty badly. My buddy helped me do the change to Amsoil about a year ago now... I haven't had lockout issues since. I've ordered the Acuity Stage 1 shifter kit and an Alta short shift adapter. I'm going to install it next weekend. I'm hoping this will help keep everything tight and also reduce the throw a little. Not sure if this would improve the lockout/grinding phenomenon for some people, but it's an idea.
AREA
Houston, TX
18 Civic SI coupe
Which are you using? The amsoil synchromesh states on the back of the bottle not for limited slip differentials.
.grimace
Byron
Reno, NV
2021 Honda CTR, 2022 Range Rover , 1990 CRX SI
Changing transmission fluid cannot void the engine warranty lol. That’s like saying I added these brake pads and now they won’t fix my suspension. Don’t let the dealership play you like that.
