Amplified Sub
gabrielanez97
Gabriel
2016 Honda Civic Ex
So I recently bought an 300WATTS Blaupunkt 8” under seat powered subwoofer looking for tips and installation guides. I ordered a LOC (low output converter) as well. Please any tips, guides, and photos will be appreciated!
Honda Civic 10th gen Amplified Sub 5F9CA82B-C62C-49F4-BD47-2B7FE71BAB8F
shoegazer
Raleigh NC
2018 Civic LX Coupe 2.0 (CVT)
My only advice would be to consider installing it in the trunk. That particular unit seems to have reliability issues that, I assume, are heat related. You could use the rear speakers for the input and focus your EQ settings to make the fronts sound best; then dial in the sub to taste. Of course; you still have to run power, ground, and remote wires to it. And the power rating is 300 watts peak; not RMS. So it's really a 100 watt sub.
Maybe run a temporary power source and see how it sounds before taking the plunge.
Good luck.
SCOPESYS
Geoff
MD
Good luck.
I don't believe it is quite that bad :
300 watts peak is 300 *(square root of 2) = 300 * 0.707 = 212 RMS
Still looking at a 30A fuse for the power, and pretty heavy gauge +12v Power line !!
Won't run long without the engine running if you turn it up high !!!
Ref: see
https://www.reference.com/science/convert-1-watt-rms-2ede9a0a9fddd047
shoegazer
Raleigh NC
Yeah. Their product page says 100 RMS/ 300 Peak. So who knows!
They also spelled 'base' incorrectly' :) So there's that.
But I hope it works. We all could use some more bass.
gabrielanez97
Gabriel
2016 Honda Civic Ex
Good luck.
I installed it under the front seat to be honest It sound amazing
shoegazer
Raleigh NC
Coolness. I'm glad it worked out well for ya'.
Boosted1one
Crystal Black FI FC1 Si ✓
Did you end up using the high low converter? Which one? And how did you wire it?
(Im currently installing an underseat as well)
gabrielanez97
Gabriel
2016 Honda Civic Ex
I used the PAC SNI-15 2 CHANNEL ADJUSTABLE LINE OUTPUT CONVERTER 10:1 REDUCTION NEW AUDIO, wired directly from my back speakers
Boosted1one
May I ask why the back speakers?
It seems everyone recommends tapping the fronts
daPyr0x
K-W
2016 EX-T
Backs are easier to get to. Fronts will give you better sound. The rear speakers do not get the full range of output from the HU.
xenon04
Czech Republic
Civic Sedan 1.5 MT
I wanted to leave room for legs under the seats and space in the boot
I bought an active spare tyre 11" subwoofer with amplifier that has a high level input
so far I have connected it to the rear speakers, it was a quick and easy way at the sedan
I plan to order the LC2i and then connect the to front speakers and the amplifier to the LC2i via the RCA cable
Honda Civic 10th gen Amplified Sub 48764637582_b1d72f4b55_c
86salmon
It's Hedley, Hedley Lamarr!
Chucktown, SC
That's neat! What do those run cost wise? Also, what sort of specs?
xenon04
Czech Republic
Civic Sedan 1.5 MT
I decided between:
Nakamichi NBF150 - 2 x 5x9" sub and 120W - https://nakamichicaraudio.com/products/nakamichi-nbf150a
Pioneer TS-WX610 - 2 x 4" sub and 200W - https://www.pioneer-car.eu/eur/products/ts-wx610a/specifications
JBL BASSPRO HUB (not available in my country) 1 x 11" - 200W - https://www.jbl.com/car-subwoofers/JBL+BASSPRO+HUB.html
finally I decided for ESX VISION V1100A - 1 x 11" sub 150W - https://www.esxaudio.de/english/vision-v1100a-active-subwoofer-system.html
with spec:
28 cm (11”) Active Subwoofer System
Integrated Class A/B Amplifier
1 x 150 Watts RMS / 1 x 300 Watts MAX
LP 50-150 Hz, Bass Boost 0-12dB @ 45 Hz
Frequency Range 20 – 150 Hz
Honda Civic 10th gen Amplified Sub 1200-L-caraudiovido-esx-v1100a
