ALTA Performance Solid Shifter Bushing
  1. ALTA Performance
    Apr 19, 2018
    43
    60
    Occupation:
    Manufacture of After market performance parts
    Hillsboro, Oregon
    2017 Civic Type R
    Feel more connected to your car during each gear change with the ALTA Solid Shifter Bushing.
    ALTAPerformance.com
    REDUCE THE SLOPPY FEEL
    The ALTA Solid Shifter Bushing reduces the sloppy and imprecise feeling during quick gear changes. This improves driver confidence by creating a precise feel while shifting, especially that crucial 2nd-to-3rd shift.
    While this seems like such a minor issue, the change in feel to the driver is immediate. You will wonder why you didn’t install this the day you purchased the car!
    This image shows how much your OEM bushing will flex during gear changes.
    CONSTRUCTION AND FINISH
    The ALTA Solid Shifter Bushing is made from lightweight aluminum and CNC precision machined for a perfect fit. Then anodized red with a laser etched ALTA logo. Anodized finish is both sleek and helps protect the part for many years to come.
    SOLID BUSHING
    The ALTA Solid Shifter Bushing is solid aluminum with specifically placed O-rings to eliminate the slop but still allow for natural drivetrain movement. Simply replaces the OEM rubber shifter bushing and is incredibly easy to install. No special tools required.
    Compatibility
    2016-2018 Civic, manual
    2016-2018 Civic Si, manual
    2017-2018 Civic Type R, manual
    2tone thanked this.
  2. FK7Hatch
    FK7Hatch Senior Member
    Jan 4, 2017
    258
    154
    MD
    17' Civic Hatchback Sport
    Just received and installed mine... Any reason why you only replace one and not both of the bushings like everyone else?
  3. OP
    ALTA Performance
    Apr 19, 2018
    43
    60
    Occupation:
    Hillsboro, Oregon
    2017 Civic Type R
    #3 ALTA Performance, Oct 8, 2018
    Awesome thank you for your support! We only have the main one because the other bushing only effects side to side movement of the shifter. We decided the added cost and install time was not worth it for the customer. This bushing really doesn't have any noticeable added improvements so no need to upgrade :) especially when most people are not shoving the shifter side to side like they would shifting up and down.
    I hope this helps you out, Please let me know if you have any more questions or how i can help you further.
    Thank you!
    Thomas,
    2tone thanked this.
