dt17
- Daryl
- Nov 11, 2017
- 6
- 124
- 30
- Bangkok Thailand
- Civic hatchback turbo 2017
Hi guys,
Basically, my question is how do i mod it to get the HP and the control of a Civic SI?
I know i can get easily
- Hondata and flash the ECU
- Tires + Rubber to 235/40R18 91W
- Larger brakes
Will these upgrades above help?
I am not sure if the Active dampers suspensions and Limited-slip differential is gonna be a easy or cheap upgrade
Below is the full list of difference from Wikipedia on current Civic SI (i removed the items that are not performance and control related)
- Larger brakes
- engine output increased to 205 HP @ 5,700 RPM (SAE net) and 192 lb-ft torque @ 2,100-5,000 RPM (SAE net)
- higher maximum boost pressure (20.3 vs. 16.5 PSI)
- lower compression ratio (10.3:1 vs. 10.6:1)
- higher-capacity MHI TD025 turbocharger (9-vane vs. 11-vane)
- helical limited-slip differential
- larger front brake rotors (12.3" vs. 11.1" vented front and 11.1" vs. 10.2" solid rear)
- two-mode damper system with normal and firm settings
- SPORT mode replaces ECON mode - increases suspension damping, reduces power steering assist, increases throttle sensitivity, and raises the activation threshold of the Vehicle Stability Assist system
- 235/40R18 91W tires vs. 215/50R17 91H
- 7% stiffer front spring rate
- 18% stiffer front upper damper mounts
- 7% stiffer front stabilizer bar rate
- 32% stiffer rear spring rate
- Solid vs. fluid-filled front and rear compliance bushings (rear shared with the Type R)
- High-stiffness rear upper control arms (shared with the Type R)
- 26% stiffer rear stabilizer bar rate
- center-mounted polygonal exhaust outlet
- higher-flowing intake system
- 23% higher-flowing exhaust system
- 10% shorter shifter throw
- revised shift linkage
- increased rigidity of shifter bracket mount
- additional items in Driver Information Display including G-force meter, turbo boost gauge with PSI indication, lap timer, throttle percentage, and brake pressure
