Air Temperature from the vents
  1. nizarz
    nizarz Senior Member
    Apr 1, 2017
    161
    65
    Occupation:
    ATC
    Ottawa, CANADA
    2017 Civic LX
    I noticed today that when I have my air temp at the lowest temp setting, its cold. However as soon as I turn the dial to 16c the air comes out warm. Theres a massive temperature difference between the lowest setting and increasing the temperature by 1 degree. Is this normal? I wanted cool air but not cold air and there doesn't seem to be a way of doing that even when the AC is turned on.
    Can anyone tell me if this is normal or is there a malfunction with my cars blend doors for the fans. Thanks!!
  2. Gruber
    Gruber Senior Member
    Jan 27, 2018
    1,247
    700
    TN
    Mark
    Definitely not normal. I had this kind of behavior in my CR-V intermittently years ago, but then it somehow reset itself and there were no problems since then. I would try to exercise the AC controls, turn it off and on, maybe it will "snap out of it".
    nizarz thanked this.
  3. OP
    nizarz
    Apr 1, 2017
    161
    65
    Occupation:
    ATC
    Ottawa, CANADA
    2017 Civic LX
    Ive had a couple of other issues where, like you said, it resolved itself so Ill check it out when I leave work. Thank you
  4. mvela
    mvela Senior Member
    Sep 13, 2018
    942
    443
    Orange, Tx
    Was it cold outside when you were trying this?
  5. OP
    nizarz
    Apr 1, 2017
    161
    65
    Occupation:
    ATC
    Ottawa, CANADA
    2017 Civic LX
    yes sir. it was 0c here in Ottawa
  6. Rickmeister 48
    Rickmeister 48 Senior Member
    Jan 31, 2017
    1,849
    816
    Occupation:
    MI6
    Newark De
    Overlord
    2018 civic ex-t
    I can say that with my car, actually both the 17 and the 18, that there is really little difference between the lowest setting and say 68 degrees. Same going there other way not much increase from going from say 75 to hi.
    integra15 thanked this.
  7. mvela
    mvela Senior Member
    Sep 13, 2018
    942
    443
    Orange, Tx
    I have had this same problem since I bought my car. If the temp outside drops below about 40F then the a/c will blow hot no matter what I set the temp for, unless I set it for “Lo” and then it’s just freezing cold. So I have no in between. It’s either cold as ice or hot like fire. But if it’s above say 50F then it starts to work normal. I really don’t know why the outside air temp affects my a/c in the car, but it does.
  8. OP
    nizarz
    Apr 1, 2017
    161
    65
    Occupation:
    ATC
    Ottawa, CANADA
    2017 Civic LX
    Yes this is exactly what Im having
  9. mvela
    mvela Senior Member
    Sep 13, 2018
    942
    443
    Orange, Tx
    I see yours is an lx as well. My hatchback ex doesn’t do this. Only my lx does this. I really don’t understand how the outside temperature has anything to do with the inside air temp settings. I’ve been needing to take it in to the dealer to see if they can fix it. But I would need to take it when it’s cold out. I live in southeast Texas so it’s rarely that cold here.
  10. turbo lover
    turbo lover Senior Member
    Apr 7, 2016
    546
    275
    Civic Hatchback Sport Touring
    That seems normal. The temperature setting you are adjusting is for the cabin temperature, not the air vent temperature. Setting the temperature to "Lo" means you want the cabin to be as cold as possible, so cold air will come out of the vents. Setting the temperature to "15.5" or whatever is one step above "Lo" means you want the cabin at that temperature, so warm air will come out of the vents until it hits 15.5 degrees inside your car. It's similar to setting the temperature on the thermostat inside your house. If you set your house at 20, in winter the air that comes out of the vents will be much warmer than 20. In summer, the air that comes out will be much cooler than 20.
  11. mvela
    mvela Senior Member
    Sep 13, 2018
    942
    443
    Orange, Tx
    But that’s the thing, it continues to blow hot air the whole time. So it’s either freezing cold or uncomfortably hot. The A/C in a car is different than the A/C in your house. In the house the heat and cold work independent from one another. In your car when the A/C is on the temperature is controlled by baffles that will allow more cool air to mix with the hot so there are some cool or warm settings. But there is only blazing hot or freezing cold. But this only occurs when it’s around 40F or below outside. It’s weird
  12. turbo lover
    Apr 7, 2016
    546
    275
    How long is "the whole time"? Does the interior temperature ever reach the temperature that you have set? If you have 65 set but it keeps heating until 75 or above then maybe there's a problem with your interior temperature sensor.
  13. mvela
    mvela Senior Member
    Sep 13, 2018
    942
    443
    Orange, Tx
    Yes I can set it for 58 and it will continue to blow super hot even when I’m starting to sweat. It almost seems like it’s measuring outside air and not inside air
  14. Giltibo
    Giltibo Senior Member
    Jul 30, 2017
    184
    87
    Alliston ON Canada
    Gil
    '08 Accord Coupe 5MT. '18 Civic Sport Touring 6MT (Both Red!)
    The "Lo" (15 degrees) setting eliminates all heat, and activates Max A/C, no matter what the cabin temp sensor senses. At 15.5, the temperature sensor is reactivated.
    The "Hi" (25 degrees) does the reverse: Max Heat, no matter what the cabin temp sensor senses.
    So, yes it is normal.
  15. mvela
    mvela Senior Member
    Sep 13, 2018
    942
    443
    Orange, Tx
    Yes I understand how the Hi and Lo work. But in between it uses baffles to control how much heat is mixed with the A/C. That is how you can select 70 and it’s not blazing hot or freezing cold coming out the vents. It’s a blend of the heat and A/C. This is the part that our vehicles are having issues with.
    Rickmeister 48 thanked this.
