Nitrogen top ups are FREE at Cosco, so why not use their dry nitrogenI agree that probably the most important thing is that it’s dry. Moisture in a tire will cause them to expand and retract in different temperatures just like a balloon does. I’m using a balloon as an example. Because if a balloon is blown up with moist air and you put it in the freezer you will see it shrink. Then pull it out in the warmth and it will expand. So I guess if either the nitrogen or air is dry then you should be ok
That's what I use. Cheap as hell. Even my portable 12V compressor is compatible.I'm sticking with good old 78% Nitrogen ;-)
And I'll guaran-doggone-tee that the drivers at the autocross paddock aren't walking around with tanks of compressed nitrogen when they set their tire pressures. One of the noises you always hear is the rattly "BRZRZRZRZRZRZRZRZRBZRBZRBZR" of portable tire inflators.The differences are ZERO.
Pressure still needs to be checked / filled.
When you are in a formula 1 race car (or similar) - the difference in time spent adding air can be the difference in a race. Other than that, air is air.
Yes and no.The differences are ZERO.
Notrogen is a total bullshit, normal air is composed of 79% oxygen. So for those who really believe that at our atmospher putting nitrogen in tires will be better than normal air, sorry but you're wrong. It doesnt improve anything. But, if you plan to fly with your car at 30000 feet above the ground, yeah you might consider nitrogen.
