Aftermarket subwoofer/amp install
sardaukar
Immanuel
Fayetteville, North Carolina
2017 Civic EX-T, 2008 Nissan Titan
Has anyone installed an aftermarked sub/amp with the stock head? I've got a Scosche LOC that I would like to use to tap for a signal to the amp. Can anyone recommend a good place to tap into for a good signal? Would this be a recommended route? Thanks for all the info.
kperalta
AluminiumCivic
Colorado
2016 Honda Civic Touring
Behind the head unit of your RCAs are long enough.
sardaukar
sardaukar
Immanuel
It seems as though if I would be tapping into (presumably) speaker wires at the back of the HU then why not do it further down the line so to speak. Is there any reason not to just tap into the rear speaker wire in the trunk?
rplush
NY
2016 Civic EX
The sound signal on the rear speaker is not as full range as the front. Try to get a T-harness from Axxess if you can that way you don’t have to splice anything. AX-DSP-HON2. And make sure either your LOC or your amp has some type of system where you can mitigate bass roll-off or your bass won’t be loud the more you turn the volume up
sardaukar
sardaukar
Immanuel
I have a bass controller that I plan on using to help mitigate some of these issues (https://www.amazon.com/gp/product/B001AV5ZHG/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1)
rplush
NY
2016 Civic EX
ah ok. if you can return your Scosche LOC and get an LC2i from Audiocontrol, that would be significantly better. It'll have "accubass" to restore that bass and its not a passively powered LOC like what you have. You'll have a much more clean input to the amp AND provide a remote turn on coming out of the LC2i.
My current system is an AX-DSP mounted right behind the head unit taking in Hi inputs and processes and SUMS the range. Then its Lo (rca out) to my amplifiers ACM-4.300 for the 2 sets of 2ohm components and ACM-1.300 (with Accubass) for my RF P3 10". The HPF and LPF is done by the DSP so each signal going into the amplifiers are already as clean as it can be with the current setup
Honda Civic 10th gen Aftermarket subwoofer/amp install JiXmVjQ
kperalta
AluminiumCivic
Colorado
Whatchu needa do is buy the ACM 5.600 plate for those sexy amps https://www.sonicelectronix.com/item_175025_AudioControl-ACM-5.600.html
rplush
NY
2016 Civic EX
kperalta
AluminiumCivic
Colorado
When I was designing the whole system, I planned on getting the plate. But the way I have everything mounted under the seats, it wouldn't be practical when i need to take some screws off to adjust the gains and what not. Here's what it looks like when i need to adjust things. Scuffboys™ in the house!
Aww, well technically it is less screws to remove the bigger plate. If you ever decide to get the plate let me know. I've got 5 on it!
Ben0012
Ben
Virginia
2017 Civic LX Sedan 2.0 CVT
Honda Civic 10th gen Aftermarket subwoofer/amp install 8B1DB69A-EA53-4D7C-97BD-8718F2D2FFFE
Second the AudioControl LOC option. Can’t go wrong with their products, I went with the LC6i, it’s tapped into read of head unit. Might be useful if you want to add a second amp and maintain fader control.
sardaukar
sardaukar
Immanuel
Romeoridgee
Honda Dealer Tech.
Rob
Maryland
19 SPT 17 EX-T 08 LX 21 CRV 12 Acc 14 328I CONV
what was the process of screwing into the rear seat? what exactly was the screws screwing into?
Phy
TN
The metal seat frame. no padding on the back of the seat, so it's easy to find them.
Romeoridgee
Honda Dealer Tech.
Rob
Maryland
Did you drill a hole first or did you just say f it just drive a wood screw through the seat frame?
