after TSB for grinding noise on warm start...its BACK a year later
  1. elykoj
    elykoj Senior Member
    Feb 5, 2016
    379
    65
    cleveland ohio
    2016 civic
    just after a year later the warm start grind is back and I am not happy. Has anyone else here had the fix and it has returned??? What has Honda said about it? I am dropping mine off on Thursday for them to look at.
  2. vctsonicgrey
    vctsonicgrey Senior Member
    Nov 24, 2016
    75
    Merryland
    '17 Civic Hatchback
    Yup, seems like it's on it's way back. I can hear it again, not quite as loud as before on every third or fourth warm restart. My service bulletin repair was more than 6 months ago and yes it's going back on their dime. ........Honda, second time around means need to install heavier duty CVT from this point on.
  3. 4l4n1115
    4l4n1115 Member
    May 21, 2016
    GTA, Ontario, Canada
    2016 Honda Civic Touring
    Seriously? I had my early 2016 Touring sedan repaired for this issue exactly a year ago (July 2017) and the issue hasn’t repeated since. I do recall on the TSB that the grinding noise has to happen at a very specific heat soak. Can you describe the driving conditions when this happens again?
    I live in Canada and I had to argue with my dealership and brought them the bulletin from Honda America for them to fix it. But since then I have not heard any grinding noise. I was pretty happy Honda fixed the problem until I see your post now...
  4. OP
    elykoj
    Feb 5, 2016
    379
    65
    cleveland ohio
    2016 civic
    this grinding noise is driving me crazy again. At my last oil change I brought it up again and they stated they could not duplicate it so did not do the TSB again. My concern is my car is about 5000 miles from being out of warranty at 36,000. Will I be shit out of luck or does this fall under the power train warranty with it being a valve body issue in the CVT??
  5. Shankmeyster
    Shankmeyster Senior Member
    Mar 15, 2017
    2,774
    1,281
    AZ
    2017 Civic Sport Hatch 6MT
    powertrain if it's trans or motor
  6. OP
    elykoj
    Feb 5, 2016
    379
    65
    cleveland ohio
    2016 civic
    WHAT IS MILEAGE AGAIN FOR POWERTRAIN WARRANTY?
  7. Lunar
    Lunar Senior Member
    Oct 23, 2016
    382
    153
    NorCal
    2016 Civic Touring Sedan
    5-Year/60,000-Mile Powertrain Limited Warranty
  8. vctsonicgrey
    Nov 24, 2016
    75
    Merryland
    '17 Civic Hatchback
    So...... has anyone had their CVT warm start up noise issue repaired twice using the TSB bulletin?
  9. OP
    elykoj
    Feb 5, 2016
    379
    65
    cleveland ohio
    2016 civic
    I am curious on this as well, Honda telling me it was repaired with the updated part and should not be happening. Well it does but both times a dropped it off they said they could not duplicate.. pissing me off
  10. Shankmeyster
    Mar 15, 2017
    2,774
    1,281
    AZ
    You don't drop it off and expect them to hear it because 90% of the time they won't drive it or they'll tell you they can't hear it because they don't know what you are hearing. Tell them you need to drive with someone to show them the issue if you really want it fixed.
  11. OP
    elykoj
    Feb 5, 2016
    379
    65
    cleveland ohio
    2016 civic
    they are aware of the issue, its been fixed before.
  12. HatchorNada
    HatchorNada Senior Member
    Jun 1, 2018
    154
    blargh, this is balderdash..
    civic Hatch
    I would have just used some clearanced out Idemitsu from AAP and a FRAM ultra filter and called it a day. you didn't get the memo but just a FYI, I got the hatch and using the FRAM Ultra got rid of the warm and sometimes cold start grind.
  13. OP
    elykoj
    Feb 5, 2016
    379
    65
    cleveland ohio
    2016 civic
    engine oil and a FRAM filter got rid of your grind from the CVT valve body?? lol
  14. Hassan
    Hassan Member
    Aug 23, 2016
    Usa
    Civic exl 2016
    Guys:
    I had the same problem, 2 times repaired and 5 time complained about it before they duplicated, did not fix the problem, I claimed lemon law and so far honda offered 10k and keep the car, also honda paying 9k to the lawyer. So if you guys did repair 2 times and the problem still there, go head and claim. Good luck
  15. OP
    elykoj
    Feb 5, 2016
    379
    65
    cleveland ohio
    2016 civic
    Car is at the dealership this morning..they are trying to duplicate it again, I told them its exact same issue as first time...went away for several months and now its back. So do you need to get a lawyer to claim lemon law?
