After market lip for civic sport (replaces stock lip)
  1. tdurham19
    tdurham19 Member
    Jul 10, 2018
    45
    Baltimore
    Tony
    2018 civic sport hatch
    A couple of weeks ago I damaged the front lip of my 2018 civic sport. There was a few people on the forum that had this problem but no fix. The damage was just cosmetic, no structural damage. A new lip from the dealer was around 500$ so that was not an option. Online it seems all the lips for the sport mount under the stock lip, this wouldn’t work. So I bought the Bayson R lip for the Si on eBay
    https://www.ebay.com/itm/TR-Style-F...176041?hash=item5211b1b0a9:g:0LkAAOSwF2FbwUMA
    After test fitting the new lip, it fit perfectly over the stock lip. All the mounting points lined up either to the bumper or the stock lip. To keep everything in place I had to also reinforce the stock lip and added about 8 self tapping screws to secure the stock lip to the bumper.
    F40EB1B6-61A9-427C-A314-CBAD903F975B.jpeg F1EF60F1-17FF-4DCD-98A8-99B3ABFD421C.jpeg 4B36F9D0-A208-4565-90FE-0E729A9689ED.jpeg 0D80CE7F-E067-40CA-A287-F232DBB51409.jpeg
    The lip does come with a pretty decent finish, however, I had some spray paint laying around so I did do about 3 coats of black, a couple coats of clear, and wet sand and polished it.
    Overall I’m very happy with it. The lip does stick out more then the stock lip but it is nothing crazy. Some people might not like the little winglets on the side, but they do go well with how the side skirts flare up.
  2. hobby-man
    hobby-man Senior Member
    Jun 20, 2018
    559
    361
    Mississauga, ON
    2018 Sport Touring Hatchback 6MT
    Sorry, perhaps I'm not understanding. Why did you test fit this lip over the damaged stock lip? It sounds like you installed this lip over the stock lip, but it looks like you removed it from the pics?
  3. OP
    tdurham19
    tdurham19 Member
    Jul 10, 2018
    45
    Baltimore
    Tony
    Yes I did not remove the stock lip. You can’t do that because Honda designed the lip so it extends far back and is used as a plastic cover for under the bumper. If you remove the lip you will have a huge hole under your bumper.
    Remm and hobby-man thanked this.
  4. CivicPlease
    CivicPlease Senior Member
    Apr 29, 2019
    109
    51
    Rowland Heights
    Civic Sedan
    I love the look of this lip especially with the modern steel color.
    This question is off topic but do you have a link to your front badge? That looks really well matched with the car.
  5. OP
    tdurham19
    tdurham19 Member
    Jul 10, 2018
    45
    Baltimore
    Tony
    https://www.ebay.com/itm/Black-Fron...r-Honda-10th-Gen-Civic-2016-2018/153394293958
    Thank you! The seller just put them out of stock. I figured these were cheap generic knock offs because the price but they actually came in genuine Honda packaging with part numbers and everything. The rear emblem was a little to big and I had to trim a little off the sides to make it fit.
  6. Jared_08
    Jared_08 New Member
    May 17, 2019
    arizona
    jd
    civic sedan 2009
    do you have enkei vulcan on your civic? do you have anymore pics with it and specs. thanks!
  7. fabster22
    fabster22 Senior Member
    Jan 3, 2018
    133
    131
    Keller, Tx
    Fabian
    2018 Hatchback Sport 6MT , 2018 Accord Lx
    This is awesome. I damaged my front lip as well after running over some debris on the highway. I might go ahead and pick this up instead of replacing it with the factory one. Did you use the supplied screws to secure it to the factory lip?
  8. OP
    tdurham19
    tdurham19 Member
    Jul 10, 2018
    45
    Baltimore
    Tony
    Yes, I think it came with 8 screws. Also all the mounting points it uses line up as well
    fabster22 thanked this.
  9. OP
    tdurham19
    tdurham19 Member
    Jul 10, 2018
    45
    Baltimore
    Tony
    Nope stock wheels. I can try to get more pics
  10. CBP_Sean
    CBP_Sean New Member
    Mar 16, 2019
    Sean
    2019 Civic Hatchback Sport 6MT
    The listing says (non sport), but this still fits perfectly?
  11. jforkner
    jforkner Member
    Apr 1, 2019
    Copperopolis, CA
    Jack
    2018 Civic Touring, 2018 CR-V Touring
    How much faster is the car with this add-on? Improve cornering? Mileage?
  12. jayzon831
    jayzon831 Senior Member
    Mar 3, 2017
    145
    58
    Bay Area, CA
    2017 Civic hatchback sport cvt, 2003 Acura RSX (totaled)
    Just to confirm, you were able to get the Bayson lip to fit over the hatchback SPORT lip and not the hatchback stock lip?
  13. OP
    tdurham19
    tdurham19 Member
    Jul 10, 2018
    45
    Baltimore
    Tony
    Yes the hatchback sport lip (glossy black one)
    jayzon831 thanked this.
  14. OP
    tdurham19
    tdurham19 Member
    Jul 10, 2018
    45
    Baltimore
    Tony
    I think +10hp can’t be sure tho without a dyno
    On a serious note tho. I did install the open type r style grill when I installed the lip, with these two mods my average mpg seemed to have went up a little.
  15. jforkner
    jforkner Member
    Apr 1, 2019
    Copperopolis, CA
    Jack
    Riiiight.
