KingMexico
Does Anyone have advise on how to go about adding tweeters on the 2018 hatch sport or lx model on the side panel?
Thanks
Thanks
is it an OEM panel? or you drilled a hole to install this tweeter?And if you have rear passengers you care about.
Drilled it with a hole saw. Just put masking tape over it and drilled in reverse.is it an OEM panel? or you drilled a hole to install this tweeter?
thanks
I like that a lot. I had 2-ways in the back it sounded like ****!!! Put in the components and so much better. Can’t wait till it’s amped!And if you have rear passengers you care about.
I would assume so but you should be able to just go to any of those parts places and look at the diagrams for the four-door EX and above, or whatever has tweeters from the factory.Sorry to bump an old post would these sails fit 2019 Civic 4 Door?
