16blktouron18$
I’m upgrading my system I went with 1 JLw7 8”, 600/1 JL slash using factory radio with an LC2i converter updates coming soon
You’re definitely gonna need these if you don’t want to cut any factory wire harness. Plugs right into factory subwoofer connectorI’m upgrading my system I went with 1 JLw7 8”, 600/1 JL slash using factory radio with an LC2i converter updates coming soon
i had to use a box the specs for the air space wouldn’t be enough in that small spaceDid you use a generic box or did you manage to fit it in the stock location?
It’s custom made for jl w7 turned out pretty good. It rattles a lot outside I’m thinking about applying sound skins.Custom box or generic? How did it turn out? Did you do anything else as far as audio or just sub?
You would need the lc2i to hook up the amp you’re just using the signal from the subyou can just unplug the stock sub and use the connector and install the aftermarket one straight to the existing wires?
