Yes it will.
TSP Stage 2 tune I believe is 327ft-lb tq to the wheels, this clutch is rated at 363ft-lbs to the flywheel and is slightly underrated from factory. I don't see this clutch slipping even if you gain a little more hp, but then again, I could be wrong. The way you drive could also determine the outcome, I personally would not be worried about it as I do not drive my car hard everywhere and I do not do dumb things like WOT at high gear under low rpm.How you know I believe op is only intank and tune
Yup I think the way you ride the clutch during the break in determines how much it would hold, the more you ride it the more wear it will have, so that's a higher risk for it to slip. I honestly think the 6 puck clutches would be more on the safe slipping wiseTSP Stage 2 tune I believe is 327ft-lb tq to the wheels, this clutch is rated at 363ft-lbs to the flywheel and is slightly underrated from factory. I don't see this clutch slipping even if you gain a little more hp, but then again, I could be wrong. The way you drive could also determine the outcome, I personally would not be worried about it as I do not drive my car hard everywhere and I do not do dumb things like WOT at high gear under low rpm.
Yep, keep in mind act has a 6 puck tooYup I think the way you ride the clutch during the break in determines how much it would hold, the more you ride it the more wear it will have, so that's a higher risk for it to slip. I honestly think the 6 puck clutches would be more on the safe slipping wise
I know, I'm waiting for someone to let us know how it is. I'm pretty sure it will be great as the organic discYep, keep in mind act has a 6 puck too
How lol? It’s not for saleThanks! Just got mine!
That’s the better optionYep, keep in mind act has a 6 puck too
Clutchmasters is terribleI wonder if the organic disc will hold up on a FBO car with the tsp stg 2 tune. I'm debating on this clutch, fx400, and action clutch stage 3
Since it is a puck style clutch it may have a small amount of chatter, cannot confirm though until someone tries it.I know, I'm waiting for someone to let us know how it is. I'm pretty sure it will be great as the organic disc
Ahh they probably offered you the discount deal if you give them a review lol. I got offered the same and was like nawI am the one who made that video
they never once said anything about me doing a review, I did it for me and for others out of kindness. Thanks for being negative about itAhh they probably offered you the discount deal if you give them a review lol. I got offered the same and was like naw[/I reviewed it because I wanted to document for me and for others and not because they said to.
You took it negatively lol. Anyways they offered me a deal for the low if I gave a positive review on their clutch.they never once said anything about me doing a review, I did it for me and for others out of kindness. Thanks for being negative about it
Oh really? Sheesh. But no I was not offered any sort of deal for reviewing it. Why didn't you take the deal?You took it negatively lol. Anyways they offered me a deal for the low if I gave a positive review on their clutch.
