Accidentally Shifted into reverse without clutch
  1. fabrizzio71
    fabrizzio71 Member
    Oct 18, 2018
    43
    United States
    Matthew
    2018 Civic SI Coupe White Orchid Pearl
    Hi All, I’m a new 2018 civic SI owner. I feel pretty stupid right now. I was getting ready to back out of a parking space this morning and without thinking put the gear lever into reverse without the clutch in. My right foot was on the brake so it didn’t move, but made a noise and the engine stalled. Is it possible to have damaged anything from this? Reverse is not synchronized, does this impact anything?
  2. demoPEng
    demoPEng Senior Member
    Oct 18, 2018
    54
    Occupation:
    Structural Engineer
    Ham, On, Canada
    2018 Civic Si Sedan, 2014 Ninja 300 SE
    How hard did you have to push the stick to get it into gear?
    I have accidentally tried to put the stick into reverse on my previous car before the clutch was fully pushed in, and I heard a loud grind and encountered significant resistance - then I immediately pulled the stick back into reverse. I'm surprised you managed to push it all the way into gear and stall the engine.
    fabrizzio71 thanked this.
  3. amirza786
    amirza786 Senior Member
    Oct 4, 2018
    3,105
    2,971
    Occupation:
    Director of IT
    A
    2006 Camry SE V6, 2013 Toyota Sienna LE, 2018 Honda Civic Si (SOLD), 2010 Lexus IS 350 Sport
    Hello. No, you are alright. I have done this in the past with other cars, as long as you don't do it often. A couple of weeks ago I accidentally shifted into third before fully depressing the clutch....the grinding from the gearbox was unpleasant, to say the least!
  4. OP
    fabrizzio71
    fabrizzio71 Member
    Oct 18, 2018
    43
    United States
    Matthew
    It was maybe a little harder then normal, but it happened so fast the car had stalled before I realized what had happened. It basically just went into gear.
  5. OP
    fabrizzio71
    fabrizzio71 Member
    Oct 18, 2018
    43
    United States
    Matthew
    Thank you, yes not planning on doing it again. It’s just unpleasant messing up a basic operation like that.
    amirza786 thanked this.
  6. demoPEng
    Oct 18, 2018
    54
    Occupation:
    Structural Engineer
    Ham, On, Canada
    Very interesting. I'm surprised it went into gear. But as others have said, I don't think you have anything to worry about. Just try to keep these occurrences seldom is all. I have yet to grind a gear in my Si yet, and I am dreading the screeching sound that will happen when I do.
  7. OP
    fabrizzio71
    fabrizzio71 Member
    Oct 18, 2018
    43
    United States
    Matthew
    I am surprised as well. If I had had major resistance and grind I definitely would have stopped and realized before putting it in gear. This is my first manual vehicle, and thus far I have been very careful about doing everything correctly. Shifting slowly to the correct gear, rev matching downshifts, never riding the clutch etc. With increased comfort and confidence comes the risk of doing something stupid without thinking I suppose. Definitely going to be even more careful now.
  8. boweldi
    boweldi Member
    Oct 16, 2018
    Dallas, TX
    Bob
    Q50S Hybrid
    Stalling and grinding gears is normal every once in a while, it happens. I had my 8th gen Si for 9 years and I've grinded the gears occasionally and stalled a handful of times. The car still runs perfectly with a butter smooth transmission.
    Also, you can actually shift a car with no clutch at all, obviously not recommended as it is a lot more wear on the transmission, but if the rpm\speed is perfect, the car can shift without grinding or much resistance. Like how you can move your shifter while the car is off with no clutch. So no, you didn't damage anything much
  9. Sal Bandini
    Sal Bandini Senior Member
    Apr 18, 2018
    94
    83
    United States
    2018 Civic Si
    I ground my gears countless times in my 6th gen. Sold it with over 170k miles, never changed the transmission fluid. Never had a problem with it. If the new Civic transmissions are anything like the old one you don't have anything to worry about.
  10. LilToTo17
    LilToTo17 Senior Member
    Jul 14, 2017
    2,734
    1,254
    Occupation:
    Accountant
    Santa Rosa, CA
    Kevin
    They aren't anything like the old one's lol. Quiet a few of people have wrecked their tranny's already and most have synchro issues with 2nd and 3rd gear
  11. BoostedSiCoupe
    BoostedSiCoupe Senior Member
    Mar 25, 2018
    1,197
    1,034
    Occupation:
    Driving my Si
    Cesspool
    2019 Civic Si
    theyre nothing like the old ones. since since the rsx the trannys have been made of glass. in other words, theyre shit.
    minitech and LilToTo17 thanked this.
  12. Ataricade
    Ataricade Senior Member
    Feb 6, 2018
    703
    393
    Midwest
    2018 Civic Si
    You are fine just don’t make a habit of it
  13. minitech
    minitech Senior Member
    Oct 16, 2018
    59
    Winston Salem, NC
    Josh
    2018 Civic SI 4 door
    Agreed, one my friends purchased a 2009 tsx 6speed and the trans syncros have the classic grind in 3rd gear, after i looked into it and found all the rsx information i was dumbfounded lol Sucks! Side note i will be keeping my fluid changed on a regular basis as i would anyways.
    BoostedSiCoupe thanked this.
  14. CVCTURBO
    CVCTURBO Senior Member
    Nov 8, 2018
    498
    349
    Occupation:
    Welder, Metal Fabricator, Machinist
    VA
    2018 Civic Sport 6M
    If there was a problem caused, you would of immediately realized it. Don't stress it bro
  15. aldo
    aldo Senior Member
    Mar 12, 2018
    539
    295
    Midwest
    Al
    2018 Civic Si Coupe
    As the old saying goes, if you can’t find em, grind em lol. Don’t worry these civics are made tough.
