A new - better Direct TPMS system
  1. SCOPESYS
    SCOPESYS Senior Member
    Aug 27, 2018
    2,510
    1,439
    MD
    Geoff
    #1 SCOPESYS, Feb 9, 2020
    Some time ago I posted about fitting a Direct TPMS system
    The system worked VERY well, but the only complaint I had was that the screen was not that bright.
    The screen used a VFD type display ( which was not very bright at all)
    Recently I can across the same looking TPMS system, but this used a LCD display.
    GREAT -- may be brighter, so I bought one .. BUT it was dimmer than the original VFD one. :(
    But here is the Good news.. There is Nothing you can do about the dim VFD display.
    However, the brightness of the LCD display is directly relayed to the brightness of the LED backlight.
    As it is supplied, the LCD version has low brightness Leds, so that they do not drain the unit's battery,
    BUT - there is nothing stopping you adding addition VERY BRIGHT leds, and having those powered directly off the unit's USB charging port . (5v)
    So I added 4 12Mcd leds two on each side, and the Result was FANTASTIC.
    (does require a little care and work to do .. taking about 1 hour)
    It now matches the Head unit display in Brightness ...
    Example: This pic was taken at night... it looks even better is daylight, and like the Head Unit display, it does not get washed out in bright sunlight. (will add a Day time shot tomorrow)
    Bottom line is .. it is far better than the former VFD display model (once the LCD one has been "Super Charged, with additional LED lighting)
  2. mvela
    mvela Senior Member
    Sep 13, 2018
    1,065
    520
    Orange, Tx
    Have you tested the accuracy with a tire pressure gauge? And can you post a pic of the sensors on the tires? I would like to see how they stand out.
  3. OP
    SCOPESYS
    Aug 27, 2018
    2,510
    1,439
    MD
    Geoff
    Numerous times. Today I went to Costco, and had them put 34 psi Nitrogen in all tires.
    (I will bleed off any excess tomorrow morning when they are cold).
    At Costco, when I put the Valve sensor back on the tires, all 4 read 34 psi on the TPMS display.
    I also have a similar unit on my other car (with Air). If I inflate these with using a digital tire pressure gauge, that reads to 0.5 psi, the TPMS unit always reads the same as the digital type gauge +/- 0.5 psi
    Obviously when I drive, the tires get warmer, and the pressure goes up.
    If I park in the sun, and it hits just one side of the car, one can see the tires on the sunny side are both warmer, and their pressures higher.
    It's TPMS where M stands for MONITORING, and it does a great job doing just that, and for me, is far superior to an "Idiot Light" that goes onto tell you that one or more of your tires "may" be low !!
  4. mvela
    mvela Senior Member
    Sep 13, 2018
    1,065
    520
    Orange, Tx
    Awesome! Can you post a pic of the sensors on the wheels
  5. shoegazer
    shoegazer assistant to the assistant manager
    Sep 5, 2018
    623
    302
    Raleigh NC
    2018 Civic LX Coupe 2.0 (CVT)
    My wife calls it the 'titty light'. And now that's all I can see when it comes on.
    Sivaru, SCOPESYS and Ocelot thanked this.
  6. josby
    josby Senior Member
    Dec 11, 2015
    830
    527
    Central VA
    2016 Civic Touring sedan, 2002 Viper
    There's another advantage, too, based on an experience I had two weeks ago.
    I left home and thought something felt strange with how my car was accelerating as soon as I pulled out of my driveway. Once I was up to speed, I turned my radio off to see if anything sounded strange, and it did. Right about then, the TPMS light came on.
    I turned around at the first place I could and went back home. I'd driven about 1 mile in total. The tire was totally flat. I removed the wheel and saw a screw embedded in the center of the tread. So I dropped the tire off at a nearby shop and asked them to patch it.
    They called a few hours later and said once they removed the tire, they could see it was unpatchable due to the sidewall being damaged by driving on it. So I had to buy a new tire.
    A true TPMS system like this would've told me my tire was flat as soon as I got into the car, rather than 1/2 a mile up the road like the OEM one, and I wouldn't be out $180 for a new tire.
  7. zakarybeach
    zakarybeach Member
    Feb 6, 2019
    Occupation:
    Systems Administrator
    Pittsburgh, PA
    Zakary
    2018 Civic Si - Sedan
    After my 2013 Rogue had a full TPMS system, coming to the Civic was a huge let down. Especially with the lack of spare tire, that light is scary to say the least. Just ordered one for myself, thanks a ton for your write up :)
  8. OP
    SCOPESYS
    Aug 27, 2018
    2,510
    1,439
    MD
    Geoff
    #8 SCOPESYS, Feb 10, 2020
    The LED display TPMS system display in Daylight.
    It's a very close match in intensity to the Head Unit display :)
    I have it mounted with VELCRO, and it is not going to go anywhere, unless I intentionally want to remove it or re-position it.
    This one I purchased on Ebay as well,
    https://www.ebay.com/itm/Car-Tire-P...Wireless-TPMS-4-External-Sensors/133094845955
    Unfortunately, these Ebay pics do not seem to distinguish between the VFD ones and the LCD ones. You defiantly want the LCD one if you are up to adding the extra LED back-lighting.
    The LCD one I got had the Brand-name in white silk screen just above the display.
    I removed it with some acetone, as I preferred the look without it.
    Also, while the Picture shows FL FR etc on the Valve sensors, the one I got had a graphic showing the corresponding wheel marked on a car graphic.
    The Ebay sellers seem to be using GENERIC picture, that may not 100% represent what they are selling :(
    The Picture for the LCD one I bought looked more like the other VFD one !!
    Just because they say LCD, does not necessarily mean they really are,
    (uninformed Ebay sellers !!)
    Not that you can easily tell from the Ebay pictures, the PHYSICAL devices have the Pressure Digits on the LCD one are slightly bigger than the VFD digits,One clue might be, is that the LCD has a battery Indicator on the Top RIGHT, and the Pressure digits are white, and the Car in the center is white.
    The VFD display has Yellow Pressure digits, and the Car is Blue, and it has no charging indicator.
    Maybe, if you wantto make sure you get the LCD one, order from the Ebay seller in this post.
    EspadaTiburon thanked this.
  9. EspadaTiburon
    EspadaTiburon Member
    Dec 31, 2019
    Los Angeles, CA
    Harlan
    '20 Civic Hatchback Sport
    Gonna give it a try, since the TPMS was one of the things I was unhappy about when I first got the car. Any chance you have a link to the LED bulbs that you used?
    Also, your link above doesn't work. You're missing a h in front of it.
    MaxPower thanked this.
  10. MaxPower
    MaxPower Senior Member
    Mar 2, 2017
    119
    135
    NJ, USA
    2020 Civic Si sedan ABM, 2017 CR-V EX, formerly 2005 Saab 9-2x
    SCOPESYS thanked this.
  11. OP
    SCOPESYS
    Aug 27, 2018
    2,510
    1,439
    MD
    Geoff
  12. OP
    SCOPESYS
    Aug 27, 2018
    2,510
    1,439
    MD
    Geoff
    #12 SCOPESYS, Feb 10, 2020
    The leds I used were 12K mcd (12,000) white 3mm leds ( 12k mcd is very bright)
    for example
    https://www.ebay.com/itm/50-x-LED-3...-Bright-USA-Seller-Free-Shipping/223292877074
    Then I filed them down from round, to be much smaller & flat, filing away a lot of the plastic lens, but not so much that I filed down to the metal & chip part of the led.
    Then when they were small & flat, they slid under the side edges of the LCD panel, and added to the light from the small leds what were on either side (on the Circuit board)
    Each led was wires to it's own 220R 1/2 watt resistor, epoxyed into the inside top of the case, and getting power DIRECT from the Micro usb socket. ( Some careful soldering required)
    Maybe I'll take it apart this weekend, and do a write up on how to do the mod.
    It certainly results in a very satisfactory unit.
  13. Chicane_Si
    Chicane_Si Senior Member
    Apr 22, 2019
    80
    Occupation:
    IT Support Assistant
    Noah
    2019 Sonic Grey Type R
    My chevy cruze and previous car, Hyundai Elantra, both have/had tire pressure read outs in the center screen but my type R does not. WHY HONDA!? Good solution, I'll definitely look into this!
  14. sLing
    sLing Senior Member
    May 22, 2018
    97
    Don't you need to rebalance your tire if you using these?
  15. davidgostbo
    davidgostbo Senior Member
    Feb 5, 2016
    490
    200
    Texas
    Honda Civic Ex-t 2016
    Could you take a picture of the sensors on the wheel? I would like to see how big they are
