A/C system noise/whistling - lets sum all the information pals
  1. charleswrivers
    charleswrivers Senior Member
    Nov 3, 2017
    2,832
    3,020
    Occupation:
    EMNCS(SS)
    Kingsland, GA
    Charles
    '14 Odyssey EX-L '18 Civic SI Sedan '94 300zx twin turbo 2001 Ford F-150 Sport
    Yeah... a phones speakers don't do a very good job of reproducing it. Played from my PC, it's pretty obvious. It's this odd squeaking that's going on. I have to turn the volume up on my phone's tinny little speaker to catch it a little. It's recorded from just above the dash, out of the path of the vents themselves.
  2. SCOPESYS
    SCOPESYS Senior Member
    Aug 27, 2018
    2,491
    1,399
    MD
    Geoff
    I'm playing it on my PC, and its not obvious what the issue is. :(
    From a purely selfish point of view, I don't need to really care -- I do not have this this issue, but it does interest me, as to what it could be, and how so many can have this annoying noise develop in their car after a period of time, and Honda Dealers cannot identify the cause or fix it.
    Their typical response seems to be 'It's Normal "
    (we are the experts, we know better than you, go away and stop bothering us, we have more profitable things to do that mess with your A/C under warranty) -- is not acceptable (at least to me)
    charleswrivers thanked this.
  3. Felix2017
    Felix2017 Member
    Mar 30, 2019
    37
    Edmonton, Alberta, Canada
    Connie
    2017 Honda Civic Coupe EX-T 6MT
    Hi - I’m very new to this forum but I’ve been reading all of your posts since last fall and I’ve been hearing the same noise at least since then. My Honda dealership initially thought it was the radiator fan that needed replacing although the tech who went for a test drive with me mentioned that it stopped when the blower/heater fan was switched off (something I discovered on my own). They replaced the radiator fan but that didn’t get rid of the noise. On my last visit (March 26), I took another tech (team lead) with me and he confirmed that he heard the noise—I asked them to check for it after they put my summer wheels/tires back on. So they think it is the A/C compressor that needs to be replaced. They want me to bring in my 2017 Civic in a week or so (April 8) because that was the soonest they could get me a loaner. And they are planning to keep it for 2 days (why?) - so I will definitely report back whether this solves the noise but I need everyone’s opinion on whether I should have to leave it there overnight - isn’t 8 hours enough time to get the work done?
    frontlinegeek thanked this.
  4. SCOPESYS
    Aug 27, 2018
    2,491
    1,399
    MD
    Geoff
    Well, it probably could be RUSHED and done in a couple of hours, but to do it PROPERLY, it should take longer.
    They have to suck (reclaim) the old R1234yf Refrigerant (well, they should !!)
    Then they should change the filter, but probably will not.
    Then they need to Suck a Vacuum and make sure that it does not leak.
    Ideally, test over a few hours, even better overnight -- - so day 2
    Then they need to recharge the system making sure they add the correct amount of THE CORRECT oil for the new R1234yf. :hmm:
    If they mess up the oil, then the compressor';s life is SCREWED [email protected]!! :doh:
    Typically, they will fill to the factory charge, check the pressures, make sure it is blowing COLD.
    If they are good, the will tweak the pressure for max Cold at the vents, (checking the pressures are acceptable) but I very much doubt if they will go that extra mile.
    Then they do the Paperwork etc etc, and finally call you to pick it up.
    Hopefully you EXPRESSLY request do not wash the car !!!(and make sure the "Service Consultant" ?? put it on the ticket before you leave after dropping off the car) or else it will go into Detailing for a Paint SCRATCH & WHIRL Job !!
    So, yes , 2 days is not unreasonable. :)
    2 Hours and I would be very concerned :(
    Felix2017 thanked this.
  5. Felix2017
    Felix2017 Member
    Mar 30, 2019
    37
    Connie
    Thank you for explaining that - maybe I’ll even ask to show the tech your post (or at least quote some of the details) just so that they are aware of absolutely everything that needs to be done (i.e. correct oil for refrigerant) —they can laugh at me or roll their eyes all they want—I’m sure they do already since I’m a blonde female. ‍♀️ I’ve already had conversations about this vehicle with the service manager as well as the assistant service manager and I’m definitely not afraid to contact Honda Canada on this. Hopefully I won’t need to. Thanks again.
  6. SCOPESYS
    Aug 27, 2018
    2,491
    1,399
    MD
    Geoff
    LOL .. why don't you do the opposite.
    Ask them to explain in detail what they are going to do, and how, and then mentally compare it with what you believe should happen.
    Then when they do not mention a new Dryer filter, or the process of putting the oil in, THEN start asking them why they did not talk about that !!!
    If they realize you known what you are talking about, they may be far less liable to skimp on what should be done.
    Have some fun !!! why not ... they won't be rolling their eyes for long once they realize that the Blonde Lady is not as Technically Challenged as they probably incorrectly assumed.
    Try asking them if they are going to fill with "the good POA oil" or "just PAG oil" for the R1234yf Refrigerant --- and when they say, its oil for R1234yf, push then, -- well, is that POA or PAG ?
    (hopefully they say PAG !!)
    I wish I could be a fly on the wall, could be a riot !!
  7. Felix2017
    Felix2017 Member
    Mar 30, 2019
    37
    Connie
    #67 Felix2017, Mar 30, 2019
    I knew I needed to think through my approach a bit more :rolleyes:—so glad you are there to coach me on this—you rock!
    I really hope other owners read these posts so that they will be just as informed/knowledgeable when they approach their own service department.
  8. Gruber
    Gruber Senior Member
    Jan 27, 2018
    1,303
    732
    TN
    Mark
    I would advise against it.
    Unless you have some actual knowledge, they will quickly realize you don't actually know what you are talking about, and they will get aggravated at the superficial knowledge from the internet. The better mechanics they are, the more annoyed they will be.
    Soon the roles may reverse and they will have fun selling you some blinker fluid.
    You may want to be vigilant, or try to make sure the guys who do the work are experts, but don't pretend you know what you don't.
    Nothing can be fast that has to do with recovering refrigerant, pulling a good vacuum, looking for leaks, testing an AC system.
  9. Felix2017
    Felix2017 Member
    Mar 30, 2019
    37
    Connie
    Point taken. The guys at this dealership pretty much know me by now and they know I don’t have any expertise when it comes to replacing an A/C compressor and all that that entails. Plus I don’t think I’m a good enough actor to pretend that I know what it’s all about. It is helpful, however, to have the whole process explained, and I am grateful that someone has taken the time to explain this to me. I do think the work order should give a detailed account of what was done, and I may ask them to supply some particulars about that, which would probably be prudent, wouldn’t you say? How would you suggest I deal with a beginning work order or a final account that is pretty skimpy on details? Any other helpful advice you or anyone else can offer is definitely appreciated!
  10. SCOPESYS
    Aug 27, 2018
    2,491
    1,399
    MD
    Geoff
    Starion, repeet and Felix2017 thanked this.
  11. Felix2017
    Felix2017 Member
    Mar 30, 2019
    37
    Connie
    Just wondering if there is still no return of A/C noise—I’m getting my compressor replaced a few days from now for the same reason.
  12. Felix2017
    Felix2017 Member
    Mar 30, 2019
    37
    Connie
    Anything new to report? Did they replace the compressor?
  13. frontlinegeek
    frontlinegeek Senior Member
    Feb 25, 2018
    677
    265
    New Brunswick, Canada
    Jason
    2010 CRV, 2017 Civic EX Sedan Honda Sensing
    I was in to the dealership today and spoke with the service manager and discussed the situation and he was perfectly fine with starting with an evacuation and recharge. He has not had anyone come in yet to complain other than me and nothing come down from Honda Canada on it. He did say that on other models and years of Honda vehicles that having too much or too little coolant can cause the sound as I described it.
    I am not in a super rush to get the work done so I haven't booked it in yet but will either for the end of the month or mid May. I am also kind of hoping that Charles gets a few more weeks of just a recharge on his Si to see how that pans out.
    One thing that I thought of and that the service manager agreed on was that changing that part is not conclusive as the procedure requires evacuation and recharge so you are doing two things at once and not legitimately knowing which it is that fixed it for real. Same could be said about the compressor. Gremlins suck...
  14. SCOPESYS
    Aug 27, 2018
    2,491
    1,399
    MD
    Geoff
    Same question to you, as I asked Charles.. (wuth no reply)
    Did the Dealer check the A/C Refrigerant Level (Pressures) before doing the evacuation and recharge ? It's a pretty critical piece of information to solve the puzzle .
  15. jeb
    jeb Senior Member
    Aug 15, 2016
    154
    81
    Halifax NS
    18 LX Hatch 6MT, 15 Forester Limited w/tech
    Hey all! I posted this in another thread, but it seems relevant here too. I am getting the same exact noise you guys are when the AC is on, and my dealer found the charge low on the AC system and a leaking condenser.
    Also apparently I need a fuel door actuator.
    Dealer States:
