9" Aftermarket Android Head Unit (Feature Overview / Installation)
elefas
Greece
civic 4dr MY2017
If I remember correctly, I had to do two things. In my iPhone's bluetooth settings where it listed the headunit (I think mine was called "CAR-KIT"), I had to click on the info ("i") button next to it and enable Sync Contacts. Then in the head unit in the phone app, go to the contacts section, and I think there was a refresh or circular arrows-type of button at the bottom that syncs the contacts via bluetooth.
Confirming it works this way! Many thanks!
jayzon831
Bay Area, CA
2017 Civic hatchback sport cvt, 2003 Acura RSX (totaled)
normally you have a fm amp in rear right if you don't power this unit(or bypass) signal is very slowly
for without amp stereo premium
for sound change speaker because speaker stock are very bad
Thanks for the input, but the LX and Sport model do not come with the FM module in the rear. Only the EX and Touring models apparently.
raulnor516
O'Fallon, IL
2019 Civic Hatchback Sport
Check out the diagrams again. They show that the non-premium audio (LX/Sport models) don't have that Amp, instead they route a cable directly to the antenna. That might be what you need to intercept instead.
nags
2019 Honda Civic Sport
Has anyone bought this version off of amazon? My concern is the oil life being gone. I don’t care abt not seeing that, I’ve not had my 2017 LX sedan long enough to get an oil change yet and saw that you have to reset the maintenance reminder from the oil life on the tachometer. Would I still be able to reset the reminder? https://www.amazon.com/dp/B08131TFD...olid=3RNZDIWX58AL8&psc=1&ref_=lv_ov_lig_dp_it
http
I was just thinking the other day that I should be overdue for an oil change right now and I checked it showed I was still at 50% life. This didn't even cross my mind as a possibility until seeing your post. Has anyone else experienced this?
Gmgunter
Greg
Alabama
2017 Civic LX Sedan
I think I worked out that the higher trim packages can see their oil life and maintenance reminders on their head units and went ahead and bought mine. So it shouldn’t affect the oil life on the dash. I think it actually tracks viscosity and mileage so maybe it just seems to be lasting longer bc it’s more accurate. Hopefully. I’m 5k into my next change and only showing 50%
nags
After posting my reply my oil % finally went down a bit so you could be totally right.
JessC
Jes
New Jersey
I just ordered one and I'll try and put it in next week but my question is, where do you put your phone? The space above the shifter is a bit cramped. Do you have a dashboard mount for your phone or what? Just curious.
Logix
Tampa
si
Has anyone rooted one of these Chinese units? I'm going to give it a go when I get mine
kittyrichie
Birmingham, Alabama
Does the PX6 have carplay? Is it worth getting the unit with built in carplay or just get the dongle? I have been weighing whether I should get one of these for over a year. I am close now, and just trying to get the best info before purchasing.
JessC
Jes
New Jersey
The one I bought has wireless carplay I'm installing it this weekend to give it a shot.
qylie
Danny
Sweden
Honda CIVIC 1,5 Sport Plus
Anyone has install this on Honda Civic Hatchback Sport 2018 ?
Law
Tampa
2017 Honda Civic Hatchback EX
I ordered the newest one with the wireless carplay. I'm also running a pair of 12" alpine subs and replaced all the speakers. No problems so far and I've had it installed for about 3 weeks now. I have a 2017 Hatchback EX. The lane watch camera works fine - there's a slight delay when I turn on my directional but it's not a big deal - you could just turn on your signal a second earlier than you normally would. The unit boots up quick and auto connects to phone (I have an Iphone XR). Sound is pretty good but the radio antenna isn't great. I play off Itunes/Spotify and a flash drive so this isn't the biggest issue to me. Steering wheel controls all work perfect. Fairly easy install - all plug and play. Here's the unit I bought and this is the best price you'll find. After hours and hours of research I determined the Daisata units were the best of the android head units so I made sure to buy one of those.
https://www.aliexpress.com/item/32992517178.html?spm=a2g0s.9042311.0.0.26624c4dPyUNJh
