SCOPESYS
- Geoff
- Aug 27, 2018
- 68
- 2,505
- 1,550
- MD
- 2018 Honda Civic SI Coupe. . . . . . . .1987 Nissan Maxima Wagon. . . . . . . . . . .1987 Nissan Pulsar NX . . . . . . . . . . . . . . . . . .1987 Nissan Maxima Wagon (2nd Donor Wagon for parts)
Honda states that the 10 Speaker Infotainment Unit is 450W system.
How did the arrive at that ??
( Its 450w Peak, not 450W rms of course !!)
450W peak is quite a bit less than 450W RMS
Well, assuming charging battery voltage is 13.4 v
Max power from a amp running with a 13.4 v rail into 4 ohm speaker is
P(peak) =V*V/R = (13.4 * 13.4 ) / 4 = 45 W (Peak)
45 / Sqrt(2) = 31.8W RMS
45W (peak) looks better than 31W (rms) so, lets use peak, without actually saying that it is peak power.
10 speaker * 24W = 450W (Honda spec)
(Maybe the SUB Speaker is 2 Ohms, but the above is close enough).
If the Sub really is 2 ohms, it should be capable of twice the power of the other speakers. (*ie 90W )
If that SUB channel in the Amp can deliver that amount of power without going into current limit !!!
But, if in the 10 speaker system, there are 4 Tweeters,
Those tweeters should not be being driven to 45W each !! . If there were, it should sound like there is no Mid or Sub at all -- all High Frequency from the Tweeters.
So, after all that, I really have no idea how Honda came with the 450W power rating for their 10 channel system.
450W sure looks good in a Spec, and should sound pretty good as well, but apparently it does not sound so good in the actual car
