+3psi map help?
das borgen
Richard
Columbus, Ohio
E36 M3, Ducati 748, '17 EGP Si Coupe
any way to do a +3psi tune? What would the tables look like in order to do that?
Thanks in advance!
dc2turbo
usa
civic,teg
How much PSI are you looking to run. it's much easier to just set that up that way
Or take out .225 mBAR above 3500 rpm
would look like something like this but it's an half ass adjustment
das borgen
das borgen
Richard
Columbus, Ohio
3psi fewer than the +6psi ultimately gives you.
Do you mean take out 0.225bar? 0.225bar = 3.2psi.
So according to my math taking out 0.225mbar would be only removing 0.003psi
dc2turbo
usa
civic,teg
the problem with doing that is its not a steady "+6psi" across teh board. It's at certain cells. It's best to pick a psi you are comfortable with edit the whole table that way.
I would just make it 19 psi all above 3500 .
das borgen
das borgen
Richard
Columbus, Ohio
19psi corresponds to what value in the table in the Flashpro software? Also, isn't stock already 19psi already though?
Honda may claim 19psi but realistically most are only seeing like 16psi or so on the Si from what I've read here.
das borgen
das borgen
Richard
Columbus, Ohio
Ah ok. 19psi corresponds then to what value in the boost tables ?
I no longer use Hondata but 19psi would be 2.31 in the boost table. I'm a little rusty with Hondata so have someone verify before making changes.
