Myx
- Mar 6, 2016
- 79
- 2,166
- 2,042
- Delaware
- 2018 Honda Civic EX (Hatchback/CVT)
- Vehicle Showcase
This is to answer the question that no-one asked and is only for documentation purposes. The item is a 3" Injen exhaust I purchased used for my 2018 Honda Civic EX Hatchback (CVT). I always weigh all my modifications. It's just a sick habit I have. I post it up in case my notes get lost, computer hard drive crashes, etc. I'll have another place to reference it. It's also for anyone that may be curious as to the same things I am.
3" Injen Catback Diameters
Outer diameter - 3" ***For the most part, see below***
Internal diameter - 2.864" (72.75mm).
Pipe that connects to downpipe - 2.388" (60.66mm) Wtf!?!?
**This is a very small section of pipe. See pics I uploaded**
3" Injen Catback Weights
Frontpipe connecting Pipe - 12.4lbs (5.62kg)
Midpipe - 8lbs (3.63kg)
Muffler Pipe - 12.6lbs (5.72kg)
Total weight = 33lbs (15kg)
Stock exhaust is 32lbs.
I bought this used but purchased it because I personally believed it is the best exhaust on the market for flow. Realize that your stock exhaust is adequate for flow, even after some bolt on modifications and no hp/torque benefits (Per PRL Motorsports dyno testing exhaust). My future may include a larger turbo but that's for another thread. I love the straight through design of the Injen setup. It's simple and un-complicated.
Two gripes (If you want to call it this):
1) The so called 'muffler'. That thing ain't muffling anything. It looks like a resonator attached to the pipe. No different! I was debating having it cut off and putting an actual muffler on it. The sound from the Injen video is very 'ricer' to me. I don't like loud and droning. So I was going to take it upon myself to correct it by cutting this piece off. I would only do this on a used piece...not a brand new Injen exhaust...which I would not have purchased new anyways.
2) It's not a true 3" exhaust. All the sections and bends seem perfect to me. The exception is the piece that connects to your frontpipe. It only has a 2.388" outside diameter. This defeats the whole purpose of the rest of the pipe forward of it. May as well have a 2.388" (or 2.5") exhaust the rest of the way through. It would've reduce any unwanted extra sound (or noise) and have the same flow potential. If someone pointed this out already, my apologies. I just didn't see it anywhere. This sucks for those thinking it is 3" all the way through.
BTW: The pipe you see me connecting the Injen's small pipe section to is a PRL Motorsports frontpipe. Look at the transition. Injen's small pipe piece is pointless and defeating the purpose of airflow through a pipe of consistent diameter. I don't care either way. It's a learning experience. I can have this section modified if I like but letting folks know what they are getting into if they purchase this exhaust. I may not have connected it to the correct side of the PRL Motorsports frontpipe or right angle. I'm just showing this as in illustration on the pipe size transitions.
